what head gasket with 84mm bore?
my block and head are on their way from importbuilders(b16). the bore on the sleeved block is 84mm. can i use a stock head gasket? if not which one should i get and where is the cheapest place to buy one?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx1856 »</TD></TR><TR><TD CLASS="quote">my block and head are on their way from importbuilders(b16). the bore on the sleeved block is 84mm. can i use a stock head gasket? if not which one should i get and where is the cheapest place to buy one?</TD></TR></TABLE>
if you have a b16 block bored to 84mm, youd have to use either a cometic or a bored out b16 gasket. b20 gasket wont work
mr. gasket sells them up to 85mm in stock through summitracing, my friend adam picked one up for his 85mm b16 yesterday actually. like 60-70 bucks
crv-techu
Mar 11, 2006 04:05 PM
