B16 HP predictions
hey...
This is my setup, i want to know what i should get for my HP on the dyno..
1991 CRX Si (weighed at 2250 lbs)
B16A1
STR Cam gears (2 degrees advanced intake, 0 exhaust)
6 oz crank pulley with AEM alernator pulley
Crower Stage 2 Cams with dual springs and Ti retainers
Short Ram air with Cold Air duct
4-1 Headers with Race CAT with 2 1/2 exhaust (Open) (headers to tip is 2.5")
Custom ECU Program with 5700 Vtec and 9200 Rev limit
Fuel Pressure at 40 PSI
MSD blaster 2 Coil pack
JG intake manifold
Holley 68mm TB
the car runs at a good air/fuel when gunned.. almost full rich on my gauge..
let me know what you think...
B16A1
JG intake manifold
Holley 68mm TB
103 hp
maybe
104 hp
on 117 octane avgas you should see those figures skyrocket to
drum roll.........
103 hp
A couple of negatives is the size of the TB, the pre programed chip and the cam gear settings.
maybe
104 hp
drum roll.........
103 hp
i forgot to tell you that it's 11:1 CR roughly..
i'm getting the dyno on the 30th...
i'm guessing over 180 HP... (those cams can make a GSR alone over 200HP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxsirvtec »</TD></TR><TR><TD CLASS="quote">i'm guessing over 180 HP... (those cams can make a GSR alone over 200HP)</TD></TR></TABLE>
and i'm guesstion you have little expierience with engines and never been to a dyno before.
w-fuck-ay
Aug 8, 2003 10:48 AM
