which cold air intake do i use for 93 jdm h22a in 94 accord ex?
Old Jul 17, 2003 | 02:43 PM
jinxster's Avatar
Default which cold air intake do i use for 93 jdm h22a in 94 accord ex?
do i use an accord aftermarket cold air intake or do i use a preludes? does it even matter?
Old Jul 17, 2003 | 03:34 PM
whoa its len 2's Avatar
You can use both. The accord one will bolt right up but its only ~2.5 inches wide as opposed to the prelude one which is ~3 inches. Youll want that h22 to breath more so Id suggest going with a prelude one. The prelude cai will fit but I think you gotta custom fabricate the mounts.
Old Jul 17, 2003 | 04:17 PM
jinxster's Avatar
Default Re: (whoaitslen2)
thanks
Old Jul 18, 2003 | 05:39 AM
KGAccord's Avatar
Default Re: (jinxster)
make sure you get a 97+ lude cause the 92-96 is 2.75 inches. the mounting braket does not bolt up, but it doesn't really matter. line the cut out of the whole where the pipe goes to the wheel well with some rubber and it holds tight. i sliced the little rubber hoses that were part of the stock intake system and used that.
i drive a honda
Sep 6, 2008 02:45 PM
JdmAcclude
Mar 11, 2004 07:36 AM
jinxster
Jul 17, 2003 07:16 PM
dvp95
Sep 1, 2002 10:40 AM
