1st Time Brake Install
Old Jul 17, 2003 | 01:22 PM
optikal_blitz's Avatar
Default 1st Time Brake Install
Hey all,
my front rotors are completely shot and deeply grooved as well as my pads almost completely burned through. I just ordered some brembo blanks and am about to pick up some axxis metal masters pads from the local shop. What i need to know is the following:
1)What parts do i need aside from the pads and rotors?
2)What tools/supplies do i need for this operation?
3)Where should i look for a procedure on how to do this installation?
4) Do i need to bleed the system?
Sorry for the lengthy post but i want to do this job right and i know some of you can really help. oh and i searched..came up with nothing too helpful.
Old Jul 17, 2003 | 01:31 PM
Behan's Avatar
Default Re: 1st Time Brake Install (NatakuBlitz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NatakuBlitz &raquo;</TD></TR><TR><TD CLASS="quote">
brake fluid
i could list them but just go to the link (for the procedure) that i posted below. its under brake system.
a helms manual (preferred) or http://www.icelord.net/honda/repair/
yes, you will need to bleed the system, and you need two people to do this
Old Jul 17, 2003 | 01:53 PM
bb6h22a's Avatar
&gt;&gt;1)What parts do i need aside from the pads and rotors?&lt;&lt;
Brake fluid, brake parts cleaner is okay to have,but not a "must."
YOu need a ratchet, a 14mm socket, an impact driver, a hammer, and a c-clamp to recompress the piston back in to the caliper.
&gt;&gt;3)Where should i look for a procedure on how to do this installation?&lt;&lt;
There's a link furnised on ntpog.org in addition to the one listed in the above post.
&gt;&gt;4) Do i need to bleed the system?&lt;&lt;
If you're only replacing pads & rotors, and not touching the lines, etc. then no, you won't need to bleed, but you'll need to top off the brake fluid resevior b/c it'll leak out some fluid when you recompress the piston. It's a really easy job, and while yuo're at it, you should go your tranny fluid, too.
Old Jul 17, 2003 | 02:05 PM
Default Re: 1st Time Brake Install (bb6h22a)
thanks guys! if you have any tips or suggestions that'd be great too.
Old Jul 17, 2003 | 02:54 PM
Behan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb6h22a &raquo;</TD></TR><TR><TD CLASS="quote">
good call. the last time i changed my pads i had a problem getting the piston to compress. so i opened the line and released the fluid. at which point i had to bleed them. forgot about that :hammer, soory for the misinformation
Old Jul 18, 2003 | 09:07 AM
Default Re: 1st Time Brake Install (93preludevtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93preludevtec &raquo;</TD></TR><TR><TD CLASS="quote"> forgot about that , sorry for the misinformation</TD></TR></TABLE>
that's quite alright, thanks for the information though!
hockeyMike2489
Oct 31, 2006 06:24 AM
hatchinprogress
Aug 31, 2006 10:01 PM
Archidictus
Suspension & Brakes
54
Aug 12, 2005 09:54 PM
weedtank
May 9, 2005 10:23 AM
RiCE On IcE 2
Apr 21, 2005 09:41 AM
