Speedbleeder install questions...and first time bleding brakes
Old Jul 17, 2003 | 11:49 AM
py1188's Avatar
Default Speedbleeder install questions...and first time bleding brakes
Sorry for thge noob question. I usually have the assistance of my father to help me but he won't be around for a while so I was hoping to have you guys help me out a bit.
Just picked up a set of speedbleeders ans some Motul and was wondering is it just as simple as removing the old bleeder screw and replacing it when it comes to the speedbleeder? Won't fluid come out? Should I flush fluid first and then replace the bleeder?
Any and all help is welcome? Thanks again. Sorry if this is a noob question just looking to get this done sometime this week.
Do I need anything special to do the bleed?
Old Jul 17, 2003 | 11:57 AM
STOLEN - ITR 98-0652's Avatar
Default Re: Speedbleeder install questions...and first time bleding brakes (py1188)
It does open the system, so you'll need to use the bleeders right after you install them. Take that opportunity to flush fluid, if its age is in any way in question (also a good time to upgrade to Cobalt Super XRF Brake Fluid - I hear it kicks ***...). So... bleeders... flush... bleed... that way you don't duplicate any work.
As far as special tools... the recovery bad that Speed Bleeders sells is pretty cool, but you can do it with some vinyl hose and any bottle. Also note that most people don't actually torque the bleeders with a torque wrench (it'd be 0.25" drive, eh?) so there's a bit of "German torque" (i.e. "Guudentite") that you need to zen.
Old Jul 17, 2003 | 12:23 PM
py1188's Avatar
Default Re: Speedbleeder install questions...and first time bleding brakes (ITR 98-0652)
Okay cool, so when I bleed the fluid, just make sure the reservoir doesn't go empty correct? If I add fluid to it, however, will the new fluid stay at the top? How do I ensure that the new fluid is going through?
Old Jul 17, 2003 | 12:50 PM
frogsr's Avatar
if you are 'flushing' then it would be a good idea to get as much of the old fluid out of the reservoir as possible with something like a turkey baster before addding in the new fluid. don't suck it dry/empty though as you don't want air bubbles getting in your lines. you can then top the reservoir off with the new fluid and bleed as necessary.
chadmasterc
Nov 3, 2003 07:44 AM
extrmeboost
Apr 9, 2003 01:00 AM
Jordan_4WS
Jan 20, 2003 02:10 PM
Floyd
Oct 28, 2001 03:40 PM
