RPM tach problem
Old Jul 17, 2003 | 11:00 AM
DesiDez's Avatar
Default RPM tach problem
well, i finally got my zc running good and smooth. but there's one problem: the rpm tach
when i go to rev the car, the needle sits at 0 and then will jump suddenly to 6k and stop. when i drove the car and floor it, the needle sits at 0 (not the idle) and will also jump to 6. it basically not reading correctly.
now, the needle sits at 8k (idle), and will go backwards when i step on the gas.
Old Jul 17, 2003 | 11:25 AM
neutron91's Avatar
Default Re: RPM tach problem (FOBsquad)
im assuming you just put the zc in... did the tach work right before you did the swap?
Old Jul 17, 2003 | 11:27 AM
DesiDez's Avatar
Default Re: RPM tach problem (neutron89)
yeah it worked fine before the engine was put it, in fact the zc was running and the tach still worked. it just started acting up yesterday.
Old Jul 17, 2003 | 11:37 AM
neutron91's Avatar
did you actually mess with the needle on the tach itself... i did this once and when i reinstalled it the tach didnt work at all... the needle was just stuck... i took it off again and put it back on slightly looser and it worked fine
Old Jul 17, 2003 | 11:43 AM
4crx4me's Avatar
I'm not sure if this will help, but did you mess with the wires inside the dizzy that attache to the igniter at all?
When I bought my LS teg, the tach didn't work right and members told me to make sure the wires on the igniter were good and tight. That fixed my problem.
HTH
Old Jul 17, 2003 | 12:02 PM
Blaze45's Avatar
Brrraaaap!
Default Re: RPM tach problem (4crx4me)
I would double check the wires on the ignitor, my tach sometimes jumps from like 5200rpm to 6800rpm, cause my ignitor wires arent on tight... then I hit the gay rev limiter....
Good Luck
Blaze
Rotten Egg
Aug 24, 2009 10:20 PM
AMChev
Nov 1, 2005 05:49 AM
5thgenCory
Jul 18, 2004 12:08 PM
StupidSlowRSX
Dec 24, 2003 02:12 AM
