help installing vtec controller in minime swap
hi i'm installing my fields sfc boxer series in my 91 civic si. i'm swapping the head w/ a sohc d16a6 head from a sohc vtec 94 civic ex. and i was wondering if you knew the wireing instructions for that swap. if anyone know's how to wire it any info would be greatly appreciated. if not i'll figure it out
Wiring should be the same in your car as it is for the VTEC model from your same model year. Mine is a 96DX and everything is the same as far as MAP etc. THe only difference is you have to run a wire from the VTEC controller to the VTEC solenoid, then leave the solenoid's pressure switch disconnected.
? ?? ??? u've had this swap done for like a month now! i thought everything was installed and u had the v-sfc hooked up?
I am looking to do a Ls/vtec into my crx that already has an Ls and I was wondering what would I need to do for wiring. Can I just hook up a V-afc and adjust fuel and have my vtec activated. thanks
