stock rs auto 1/4 time?
Old Jul 17, 2003 | 08:57 AM
PLRacer's Avatar
Default stock rs auto 1/4 time?
does anyone know what a completely stock 94 automatic RS should run in the 1/4?
Old Jul 17, 2003 | 09:13 AM
dohc-nyne's Avatar
16.7?
Old Jul 17, 2003 | 09:48 AM
4potnick's Avatar
Default Re: stock rs auto 1/4 time? (PLRacer)
SLOW. very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very slow.
Old Jul 17, 2003 | 09:50 AM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Default Re: stock rs auto 1/4 time? (4potnick)
Very slow
Old Jul 17, 2003 | 09:55 AM
PLRacer's Avatar
lol, bastards
Old Jul 17, 2003 | 10:17 AM
4potnick's Avatar
Default Re: (dohc-nyne)
16.71057941
Old Jul 17, 2003 | 10:34 AM
Bspec18's Avatar
Default Re: (4potnick)
16.7 at best. in my area i've mostly see 17.6 Palmdale,
Old Jul 17, 2003 | 11:11 AM
dohc-nyne's Avatar
depends on how fast u can dump that thing from neutral to d3 lol
Old Jul 17, 2003 | 11:40 AM
PLRacer's Avatar
do peolpe run them in d3 or d4?
Old Jul 17, 2003 | 11:43 AM
dohc-nyne's Avatar
gawd only knows
Old Jul 17, 2003 | 11:54 AM
Havokmkr's Avatar
There are only 3 ways to launch in an auto and only 2 of them are fullproof. The N-bomb. Dumping from neutral, this is by far the worst method and it is horrible on your tranny. Brake-Stand or power brake. push in the brake just enough to hold the car at about 1.5k or 2k and then let off and floor it. Most of the time if you hold it at 2.5k the car will bog for about 2-3 secs. because the car thinks it should be in second. The last and most efficient way is to drop it into 1st and rev up to about 2k and then let off the brake. You should chirp the tires and be on your way and then you should just shift it yourself. This is also harsh on your tranny but by far the easiest to pull off.
Edit: BTW you should run about a 16.8 or someone in there on 1/4 tank w/full interior. Just work on your launches and right before it shifts(if you use method 2) let off and then punch the gas and you will be in a higher rpm in the next gear w/out chirping the tires.
Old Jul 17, 2003 | 12:21 PM
stolenhubcabs's Avatar
Default Re: (Havokmkr)
i'd say if you shift from d1-d2-d3, you should be in the 16's, that would be my suggestion while power braking
jdmstockeg6
31
Nov 12, 2008 10:56 PM
Hites
Sep 12, 2003 08:14 AM
rave n race
Jun 28, 2001 01:38 AM
