went to track with d16y8 93 cx hatch for first time
well as some of you know i have been doing this swap for like 2-3 weeks on my spare time and i completed it last week and took it to the muffler shop to put in my testpipe and adjust my catback. here are my 3 times and setup.
98 d16y8 swap with y7 bottom end and p28
clutchmasters 9lb flywheel
act clutch
aem short ram
dc headers
test pipe 2.5"
hp racing 2.5" cat-back
ground controls on stock shocks
13" steelies with stock tires
first run
.829 rt
2.479 60'
6.776 330
10.369 1/8
68.26 mph
13.473 1000'
16.089 1/4
85.64 mph
2nd run
1.024 r/t
2.644 60'
6.946 330'
10.529 1/8
68.62 mph
13.620 1000'
16.228 1/4
86.15 mph
3rd run
1.092 r/t
2.380 60'
6.640 330'
10.233 1/8
68.50 mph
13.327 1000'
15.931 1/4
86.26 mph
I got there late so i only got in three runs. i have been racing for 7 years and this is my forst time out with this honda so i am still getting used to launching the sohc motor. this is only my second honda with a stock motor. my last run was the best but oddly my worst reaction, but my best 60'. but my 60' can be much lower. i feel the car can be running like 15.5 as is, maybe a bit better once i am used to it. i have only had it on the street for 5 days. i have a turbo in my house that will be on this motor shortly. let me know what you guys think. comments welcome!
act clutch
aem short ram
dc headers
test pipe 2.5"
first run
.829 rt
2.479 60'
6.776 330
10.369 1/8
68.26 mph
13.473 1000'
16.089 1/4
85.64 mph
2nd run
1.024 r/t
2.644 60'
6.946 330'
10.529 1/8
68.62 mph
13.620 1000'
16.228 1/4
86.15 mph
3rd run
1.092 r/t
2.380 60'
6.640 330'
10.233 1/8
68.50 mph
13.327 1000'
15.931 1/4
86.26 mph
I have that same set-up but I have been struggling with it. How did you get the o2 wired up? mine has been a wiring fiasco, that and my p28 went bad.... any tips?
the o2 was easy. i will find my papers and let you know exactly what pinouts to wire it to. i just wired it straight to the ecu. wiring just took me a few hours.
My best is a 16.2 with a D16z6 with I/H/E I only trap at 83 mph. I am over a mile high above sea leval so you should be able to do better.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by derrickcxhatch »</TD></TR><TR><TD CLASS="quote">My best is a 16.2 with a D16z6 with I/H/E I only trap at 83 mph. I am over a mile high above sea leval so you should be able to do better.</TD></TR></TABLE>
thanks man! any one else?
My best time was a 15.8 w/ 55 shot of ZEX in my D16y8.
Not a bit of traction 1- end of third + it was my first time ever at the track.
I ran a 16.0 w/ my y8 in 2500 pound coupe with short ram, DC header, and 2.25 crush bent exhaust, what is the corrected times for your runs?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2camsaam »</TD></TR><TR><TD CLASS="quote">My best time was a 15.8 w/ 55 shot of ZEX in my D16y8.
Not a bit of traction 1- end of third + it was my first time ever at the track.</TD></TR></TABLE>
not sure about the corected times
btw-all 3 of these runs were on 30 psi of tire pressure instead of like 10-15psi. my gauge was stuck so i couldn't measure it when i got there. but later i borrowed someone's and lowered it but i didn't get to race. so i will try again next week and my itr throttle body i just picked up.
plus i was launching lower than i should of b/c i am still getting used to this particular car. plus it was my first time at this track.
i just put a post up about my time, but why not contribute here?
i ran a 16.2 in my 92 hatch, stock dx (d15b7)... its lowered, has no passenger or rear seats... i'm aiming for high 15's, stock
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmsiR20 »</TD></TR><TR><TD CLASS="quote">i just put a post up about my time, but why not contribute here?
damn good time!! nice!!! my stock se-r ran 16.0 flat. that's good 4 u
</TD></TR></TABLE>damn good time!! nice!!! my stock se-r ran 16.0 flat. that's good 4 u
My stripped out 94 dx, with a D15b7, a 89 Si cam, I/H/no exhaust, DX tranny, ran a 15.5 my first time ever.
A 2.492 60 foot, 10.0 1/8th.
175/70/13s on VX wheels @ 35 psi.
I know you can go faster.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mycvc8u2 »</TD></TR><TR><TD CLASS="quote">
What do you mean ?
</TD></TR></TABLE>What do you mean ?
You can do much better.
Reaction time means jack. Your 60' needs to come down a bit.
Where did you run?
Atco?
Englishtown?
Island?
lol
What were the track conditions like? Was it hot/humid? Since you are in NJ you can't be running any higher than 90ft above sealevel. So elevation is not really a factor.
Just as an example of how much better you can do, i managed a 15.9 in my 95 EX coupe when it was bonestock...
Where did you run?
Atco?
Englishtown?
Island?
lolWhat were the track conditions like? Was it hot/humid? Since you are in NJ you can't be running any higher than 90ft above sealevel. So elevation is not really a factor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JV »</TD></TR><TR><TD CLASS="quote">You can do much better.
Where did you run?
Atco?
Englishtown?
Island?
lol
pittsburgh raceway park in new alexandria pa. i live an hour from there now. i moved from jersey 3 years ago to finish school out here. it was like 80 degrees but i think i am a few hundred or so feet above sea level out here. not sure exactly. all 3 runs were on 30 psi @ front tires. my gauge wasn't workin so i left them. hope this helps
Where did you run?
Atco?
Englishtown?
Island?
My last time drag racing was last summer.
94 Civic Si, no rear seat or spare, ported head, intake and custom exhaust,
ran a 15.5 @ 88 mph with a 2.38 60 foot.
I could list all the things I did wrong or could have changed, but that's what I ran...it's slow either way
