question about TODA cams for EP3
Hi.
Mayby somobody know answer.
TODA offer cams for K20A engine spec A. intake 12,5mm lift , dur. in290, ex290
code 14111-F20-C2A and 14121-F20-C2A
Toda offer also cams for S2000 F20C
code 14111-F20-C2A and 14121-F20-C2A Spec . A2!!!!
These same code but other spec.
lift is 13mm and dur. in295, and ex290
It is possbile using in K20A engine cams from F20C spec A2?
Mayby it is these same cams?
All info I read from http://www.toda-racing.co.jp/
thanks for info
thanks for info
the f20 uses different cams than the k20.
Also, you can't use the cams for the k20a in your ep3. You have a k20a3 which has a different rocker arm setup than the k20a. In order to get cams, you need to do a head swap first.
Hi.
I have European Honda Civic Type R Ep3, engine k20a2 200Hp,
it is these same engine what RSX Type S, I think so.
For me it is very strange why TODA cams has identical code for K20A and F20C.
thanks for info
thanks for info
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dominic-ITR »</TD></TR><TR><TD CLASS="quote">Hi.
thanks for info</TD></TR></TABLE>
ahh, didn't notice you had a euro type-r. that changes everything. :D
also, it is interesting that hte part #'s are the same.
I'm guessing it's a typo b/c the duration specs are different.
