Which swap should I do
Old Jul 16, 2003 | 07:02 PM
StRacer's Avatar
Default Which swap should I do
K, here is the senerio, I have an 89 civic si. I was thinkin on doin an b18b(u.s)swap. My friend told me to do a b16a(jdm). I was wondering what others on this site have experienced with different swaps and which ones they liked the best. This will help me findout which one i want also. Price is a factor too.
Old Jul 16, 2003 | 07:48 PM
misfithamster's Avatar
Default Re: Which swap should I do (StRacer)
mod for mod in the same car i think the b16 would be faster but people like the b18 for turbo and such, more than the b16 anyways. ive talked to swap shops and they charge the same for both, its weird. but if your a do it yourselfer all the parts and such the b18 would be cheaper and it wont leave you dissapointed. people love the torque. but it does lack in the top end. from my research anyways.
Old Jul 16, 2003 | 08:01 PM
CRX Si's Avatar
Default Re: Which swap should I do (misfithamster)
If you can get a B18b with a s1 tranny you should be able to hang with any B16... The B16 has a nicer redline but the torque on the B18 will make you happier...
Old Jul 16, 2003 | 08:11 PM
Default Re: Which swap should I do (CRX Si)
yeah thats true, the b18 with the shorter geared tranny will help.. does it affect highway driveability though? ive always wondered, i get mixed answers. might wanna look into that as well.
Old Jul 16, 2003 | 08:46 PM
CRX Si's Avatar
you could do a S1 tranny with an Ls 5th gear for highway...
Old Jul 16, 2003 | 09:24 PM
good answer.. very acceptible
Old Jul 16, 2003 | 11:02 PM
xsellxoutx's Avatar
save your money and build up the d16a6 you already have built d16a6 is cheaper than a b16a swap. i put a d16a6 in my crx hf and i used to smoke crx si's w/b16's
IMO if you're gonna go b-series go b18c or better otherwise stick w/ the d16
Old Jul 16, 2003 | 11:41 PM
Broken Gearbox's Avatar
Default Re: Which swap should I do (xsellxoutx)
yea build up the D16!
Old Jul 17, 2003 | 06:48 AM
StRacer's Avatar
What does the s1 tranny come out of.
Old Jul 17, 2003 | 10:28 AM
i think the s1, j1, and y1 with short gears are jdm trannys that came with the b16 although im not 100% positive
Old Jul 17, 2003 | 10:49 AM
50shotRex's Avatar
be careful bcuz the us integra ls, came with s1's, ys1's, and a1's.
Old Jul 17, 2003 | 11:36 AM
roadawg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by misfithamster &raquo;</TD></TR><TR><TD CLASS="quote">i think the s1, j1, and y1 with short gears are jdm trannys that came with the b16 although im not 100% positive</TD></TR></TABLE>
The S1 and J1 came out of the integra XSi/RSi's in Japan. The Y1 tranny came out of a Jap spec civic/CRX. The S1 and J1 tranny have a 4.4 final drive ratio which is geared for acceleration. The Y1 is has less aggressive gears not sure of the specifics.
Honda put aggressive gears in the S1 and J1 to compensate for the little 1.6 pushing a heavy integra and the Y1 doesnt have aggressive gears because it came out of a lighter civic. So Honda put more aggressive gears in the S1 and J1 because of the lack of torque the b16a makes.
IMO go with the b16a, unless you are going turbo in the future because the b18b has lower compression than the b16a. But from what I've seen a b16a will pull harder than a b18b with comparable mods.
Old Jul 17, 2003 | 12:11 PM
Racer613's Avatar
H series beast monster!!!!!! Loads of tq, loads of hp.....with proper suspension, and crossmember you can handle pretty good too.
I gaurantee you will own most in this set up!!!!!
http://www.collectiveracing.net &lt;-----crx/h22 woo woooo!
Old Jul 17, 2003 | 12:44 PM
Creepshow S60's Avatar
Default Re: Which swap should I do (Racer613)
lets not count out the JDM d15b sohc vtec motor. cheap and pretty effective..
Old Jul 17, 2003 | 03:52 PM
Smokinsax's Avatar
The Boot
Default Re: Which swap should I do (y-49CRX)
Go with the B16A swap then add the B20B/Z block ($700) down the road...then we'll talk about torque.
87hondaguy
Jul 1, 2011 06:58 PM
jorgejam2001
Sep 20, 2010 07:21 PM
Curbow_USMC
Aug 10, 2005 08:06 AM
ckehl13
Apr 1, 2005 05:29 PM
RacerXintegra2k
Sep 29, 2002 11:41 AM
