got new axel put in
Old Jul 16, 2003 | 06:58 PM
romeo619romeo's Avatar
Default got new axel put in
im having wobbles during acceleration.. could the axel be bad? in the low rpm only
Old Jul 16, 2003 | 07:35 PM
Esoterikos's Avatar
Default Re: got new axel put in (romeo619romeo)
check your tire pressure...and if that's okay, check if you have a damaged rim, and then check your alignment.
Old Jul 16, 2003 | 07:50 PM
Mohudsolo's Avatar
Default Re: got new axel put in (S8P-tuner)
OEM or aftermarket? I have an aftermarket driver's side axle and find a slight wobble during low speed acceleration. It does not have the small rubber "doughnut" in the middle of the shaft like the factory one does. I've had it on for about 6K miles, 5 track days, and about 75 autox runs and it's the same as when I put it in.
If it's a big wobble, it's a bad axle. I had a set of aftermarket "heavy duty" axles and they did that from new. Severe vibration above 90mph and sounded like driving on washboard pavement in hard left turns. New axles can be bad so don't assume it can't be the new one.
Old Jul 17, 2003 | 08:27 AM
Default Re: got new axel put in (Mohudsolo)
thanks ..
Old Jul 17, 2003 | 08:43 AM
AWD: Jeff's Avatar
i would just likk to add check if ur lugnuts are all tight. that how i likk my girls, but ya thats what happen to me a while back, didnt realize that i was only riding on one lug.
blake22
Suspension & Brakes
14
Sep 24, 2010 08:35 PM
slickciv
Feb 19, 2007 12:47 PM
Silent_Destruct
May 14, 2006 04:21 PM
e_r_i_c_
Apr 28, 2003 07:55 PM
B18C-RnVA
Sep 22, 2001 01:48 PM
