coolant drain bolt behind engine block
Old Jul 16, 2003 | 06:16 PM
whoa its len 2's Avatar
Default coolant drain bolt behind engine block
on a 96 accord 4cyl the engine coolant drain bolt is behind the engine block just left of the oil filter correct? how many psi is that thing bolted down? ive been here for 4 hours trying to unbolt that bastard and it wont even move. no impact tools just raw muscle here. for the guys who did a engine coolant flush how did you get that piece of **** unbolted?
Old Jul 16, 2003 | 06:25 PM
StimpyBoy's Avatar
Default Re: coolant drain bolt behind engine block (whoaitslen2)
Try a breaker bar and a long *** piece of pipe. It was extremely tight on mine as well, I eventually gave up and just went with the radiator drain only
Old Jul 16, 2003 | 06:31 PM
Accord94DX's Avatar
Default Re: coolant drain bolt behind engine block (StimpyBoy)
Breaker bar and lots of
Old Jul 16, 2003 | 06:52 PM
Stripped Honda's Avatar
99-0104
just hold the ratchet straight on the bolt and use a BFH to hit the ratchet it will break it loose ... but if your doing this just to flush your coolant then your dumb just run water through the radiator (with the drain plug removed) till the thermostat opens a few times and your engine will be totally clean ... actually cleaner then with just taking that bolt out
Old Jul 16, 2003 | 08:59 PM
Default Re: coolant drain bolt behind engine block (Stripped Honda)
im not dumb
haha anyway i just did a radiator flush.. i was planning to do the radiator and engine block but yeah that damn bolt is stuck so yeah.. oh well better luck next time
Old Jul 16, 2003 | 10:39 PM
ApexiAccord's Avatar
just disconnect the heater hose it will be alot easier its close above the oil filter. while u do that make shure that you have your heater on. so all the excess coolant pours out.
Old Jul 17, 2003 | 09:47 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: coolant drain bolt behind engine block (ApexiAccord)
That is messy. Thats what I had to do when I couldn't get the drain bolt loosened when I pulled my motor. Make sure you have something big in diameter to catch all the coolant.
Tokonut
Mar 1, 2009 06:33 PM
gailT25
Feb 23, 2009 04:39 AM
91H4hatch
Dec 26, 2006 04:51 PM
Etylorcen
Aug 15, 2002 01:24 PM
HoNdAeX11
Jul 16, 2002 04:32 AM
