what header for dohc F22b
Old Jul 16, 2003 | 06:04 PM
d98clturbo's Avatar
Default what header for dohc F22b
what header can i use for a JDM F22b dohc motor
H22/h23or f22 sohc
please help
Old Jul 17, 2003 | 06:10 AM
mugenCD5's Avatar
Default Re: what header for dohc F22b (d98clturbo)
h23 header, or you can use the 90-93 accord header, they both bolt up.
Old Jul 17, 2003 | 07:52 AM
Stage5AB's Avatar
Default Re: what header for dohc F22b (mugenCD5)
I just bought Prelude SI headers for my JDM F22B DOHC. However the header A pipes are much longer than the accords and they are off to the drivers side by about 2 inches. Using the pipes you mention did you have to customize your pipes?Did you have to change a flange or cut the header pipes? Looking at my setup it looks like I need to cut the pipes and change a flang to match the flang on my CAT. Or did I simply waste money and buy the wrong pipes?
Thanks
Old Jul 17, 2003 | 08:04 AM
mugenCD5's Avatar
Default Re: what header for dohc F22b (Stage5AB)
if u just swapped your motor over, then you need to shorten your exhaust, and move the cat back. you also have to change the flange if you havent already. i did this on my 94 accord ex. shorten exhaust piping, moved the cat back, and change the flange for the header to fit.
jdm92_accorn
Jun 4, 2014 01:06 PM
TwoKSiR
Jul 19, 2007 07:39 AM
jweezy225
Jun 18, 2006 05:34 PM
HYREV2NR
Aug 13, 2003 10:59 AM
CptCorN
Jun 29, 2003 06:23 PM
