Just got a b16 but it had been outside for a long time
Old Jul 16, 2003 | 01:48 PM
Bigjon
Guest
Posts: n/a
Default Just got a b16 but it had been outside for a long time
Ok, when I took the spark plugs out they were sitting in water and there was water in the fuel injector connectors. There is a lot of surface corrosion on the outside of the engine but it just brushes right off. It isnt seized or anything. My question is, is there anything I need to do to this thing other than letting it dry out before i put it in the car?
Modified by Bigjon at 6:09 PM 7/16/2003
Old Jul 16, 2003 | 01:52 PM
SpooN Man's Avatar
Default Re: Just got a b16 but it had been outside for a long time (Bigjon)
you should change the rotor and cap, spark plugs, oil pump, water pump, timing belt, clutch, and so on. Do what you can everything is much eaiser while it's out of the car. Trust me
Old Jul 16, 2003 | 01:54 PM
lazyvietboi's Avatar
Old Jul 16, 2003 | 02:03 PM
743power's Avatar
Default Re: Just got a b16 but it had been outside for a long time (lazyvietboi)
why 1st gen? Do you have all the stuff to convert to obd1?
Your neighbors must love you.
Old Jul 16, 2003 | 02:06 PM
blackhatchy's Avatar
Default Re: Just got a b16 but it had been outside for a long time (743)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 743 &raquo;</TD></TR><TR><TD CLASS="quote">Your neighbors must love you. </TD></TR></TABLE>
lmao no kidding
silverEH2's Avatar
are u doing the swap in an apartment complex
Old Jul 16, 2003 | 02:07 PM
B_CRUZ!'s Avatar
call the cops, someone stole your wheels.
Old Jul 16, 2003 | 02:08 PM
Bigjon
Guest
Posts: n/a
Default Re: Just got a b16 but it had been outside for a long time (silverEH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silverEH2 &raquo;</TD></TR><TR><TD CLASS="quote">are u doing the swap in an apartment complex</TD></TR></TABLE>
nope...base housing
Old Jul 16, 2003 | 02:09 PM
2000CX's Avatar
dkim48's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazyvietboi &raquo;</TD></TR><TR><TD CLASS="quote">
Nice Jack Stands.
Old Jul 16, 2003 | 02:11 PM
Bigjon
Guest
Posts: n/a
Default Re: Just got a b16 but it had been outside for a long time (dkim48)
there are jack stands behind the bricks.
Old Jul 16, 2003 | 02:13 PM
kmf0211's Avatar
STOP KNOCKIN THIS GUY...everyone does somethin ghetto in their life
That pic does make me laugh tho lol
Yea i would do timing belt,water pump,fuel pump, maybe new injectors,new plugs, rotor, cap,wires..all the rest of that good stuff..have fun
Old Jul 16, 2003 | 02:25 PM
balls 2 the wall's Avatar
do the same thing they said and check all hoses. make sure there not dry rotted. dont feel bad i tear my car down in my complex
Old Jul 16, 2003 | 02:42 PM
NrG's Avatar
NrG
Default Re: Just got a b16 but it had been outside for a long time (***** 2 the wall)
damn.. why A1?
Old Jul 16, 2003 | 02:49 PM
Bigjon
Guest
Posts: n/a
Default Re: Just got a b16 but it had been outside for a long time (NrG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NrG &raquo;</TD></TR><TR><TD CLASS="quote">damn.. why A1?</TD></TR></TABLE>
Its kinda a long story. But it is just a temp solution.
Old Jul 17, 2003 | 10:39 AM
Chilly Willy
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bigjon &raquo;</TD></TR><TR><TD CLASS="quote">nope...base housing</TD></TR></TABLE>
base housing ownz for engine swaps .. thats where i did mine
Old Jul 17, 2003 | 10:43 AM
mixxed's Avatar
Default Re: Just got a b16 but it had been outside for a long time (SpooN Man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpooN Man &raquo;</TD></TR><TR><TD CLASS="quote">you should change the rotor and cap, spark plugs, oil pump, water pump, timing belt, clutch, and so on. Do what you can everything is much eaiser while it's out of the car. Trust me </TD></TR></TABLE>
Old Jul 17, 2003 | 10:47 AM
2camsaam's Avatar
Default Re: Just got a b16 but it had been outside for a long time (mixxed)
most decisions revolve around $.
Old Jul 17, 2003 | 11:43 AM
projecthybrid04's Avatar
Default Re: Just got a b16 but it had been outside for a long time (2camsaam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2camsaam &raquo;</TD></TR><TR><TD CLASS="quote">most decisions revolve around $.</TD></TR></TABLE>
i couldn't have said it better my self
Old Jul 17, 2003 | 11:53 AM
PotatoePAPA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ***** 2 the wall &raquo;</TD></TR><TR><TD CLASS="quote">do the same thing they said and check all hoses. make sure there not dry rotted. dont feel bad i tear my car down in my complex </TD></TR></TABLE>
just replace all the hoses, regardless if they are rotted or not. That way it will give you a little more peace of mind
Old Jul 17, 2003 | 11:56 AM
xJ.SLOTHx's Avatar
gangster *** jack steezies...haha
Old Jul 17, 2003 | 11:57 AM
BROOD's Avatar
Default Re: Just got a b16 but it had been outside for a long time (SleepyDX)
I'd replace all the hoses, the accesory belts, the timing belt, the tensioner, the water pump, the sparkplugs, rotor, cap, plug wires, fluids, filters, coolant etc.
Also make sure the engine turns over freely and is not locked up, prime with oil before first startup, pull valve cover and check the valvetrain/cams.
Pretty much search with a fine tooth comb and you should be alright.
Old Jul 17, 2003 | 12:01 PM
2.0L EK's Avatar
Default Re: Just got a b16 but it had been outside for a long time (digitalBEEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by digitalBEEF &raquo;</TD></TR><TR><TD CLASS="quote"> call the cops, someone stole your wheels.</TD></TR></TABLE>
No no no.... hes using them as jack stands for the rear
Good luck with your swap!
Old Jul 17, 2003 | 12:04 PM
shivic's Avatar
Default Re: Just got a b16 but it had been outside for a long time (Si.Hatch.92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si.Hatch.92 &raquo;</TD></TR><TR><TD CLASS="quote">STOP KNOCKIN THIS GUY...everyone does somethin ghetto in their life
Yea i would do timing belt,water pump,fuel pump, maybe new injectors,new plugs, rotor, cap,wires..all the rest of that good stuff..have fun </TD></TR></TABLE>
LAMO!!! WE'RE ALL GHETTO SOMETIMES.
ya man, change all that stuff.
shouldn't he check for rust in the block?
Old Jul 17, 2003 | 12:12 PM
SiR HatchAlot's Avatar
i wonder who the jackass is that left it outside.
