proportioning valve for ABS or not?
Old Jul 16, 2003 | 01:41 PM
vizeta's Avatar
Default proportioning valve for ABS or not?
as topic says, how can u tell? Thanks.
Old Jul 16, 2003 | 01:42 PM
KRiS1's Avatar
Default Re: proportioning valve for ABS or not? (vizeta)
I think they are stamped 40/40 or 30/30 or something
Old Jul 16, 2003 | 01:45 PM
vizeta's Avatar
Default Re: proportioning valve for ABS or not? (POS Hatchback)
no no, 30/30 is for rear drum, 40/40 for rear disk...
Old Jul 16, 2003 | 02:38 PM
92sleepR's Avatar
New User
an ABS brake system doesn't have a proportioning valve, just a union between the front and rear lines (where the prop valve would go on a non-ABS system) The ABS unit handels the front/rear bias.
Mike
Old Jul 16, 2003 | 03:32 PM
vizeta's Avatar
Default Re: proportioning valve for ABS or not? (92sleepR)
but how come the shop manual says there has a prop valve for integra type R? ITR has ABS right?
Old Jul 17, 2003 | 07:31 AM
vizeta's Avatar
nobody??
Old Jul 17, 2003 | 09:34 AM
ChiBoy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vizeta &raquo;</TD></TR><TR><TD CLASS="quote">but how come the shop manual says there has a prop valve for integra type R? ITR has ABS right? </TD></TR></TABLE>
Ditto.
Old Jul 17, 2003 | 09:38 AM
DOHCtorTHRUST's Avatar
Default Re: proportioning valve for ABS or not? (ChiBoy)
i dont think it has anything to do with ABS...from the looks of it it mounts on the fire wall the same..(correct me here if im wrong)
integra 4040
civic SI\EX 3030
Old Jul 22, 2003 | 06:21 PM
EK MONEY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92sleepR &raquo;</TD></TR><TR><TD CLASS="quote">an ABS brake system doesn't have a proportioning valve, just a union between the front and rear lines (where the prop valve would go on a non-ABS system) The ABS unit handels the front/rear bias.
Mike</TD></TR></TABLE>
that is correct. the front lines go directly to the abs unit. The rears go to this union, and from there, to the abs unit and also tee off to the master cylinder.
nitewolf
Apr 3, 2009 11:26 AM
canaccord
May 13, 2008 08:10 AM
nikolai.
Jan 12, 2007 11:08 PM
Spikes11
May 4, 2004 08:41 PM
phantom_sol
Oct 5, 2003 10:22 AM
