Anyone with Koni/Gc setup regret it later?
Old Jul 16, 2003 | 01:15 PM
zijiejijeijrkjk's Avatar
Default Anyone with Koni/Gc setup regret it later?
It's a street car but I only want to buy the suspension once and don't want to regret going with a Koni/Gc setup rather then something like Jic FLT2's.
I do track the car at HPDE's but at the most ten times a year. Plan to keep the car for awhile.
Any constructive input is appreciated.
Old Jul 16, 2003 | 01:43 PM
Tweakmeister's Avatar
Default Re: Anyone with Koni/Gc setup regret it later? (scott_k)
GC 400/500 on Koni Yellows here.
On one turn of the KY it's Cadillac streetable. I keep mine about 1.5 usually.
And yes, I scream "wwaaaahoooooooo" out of every corner.
Old Jul 16, 2003 | 02:46 PM
Misfit's Avatar
Default Re: Anyone with Koni/Gc setup regret it later? (Tweakmeister)
Its an affordable great set up. Unless you just want a cute name for the street. stick with GC and Koni. I run 350 front and 450 rear. nice ride IMO.
Old Jul 16, 2003 | 05:07 PM
Renegade's Avatar
Default Re: Anyone with Koni/Gc setup regret it later? (MISFIT)
I recently upgraded out of the Koni/GC, but I never regret it. (Koni/GC 350/400 )
Old Jul 16, 2003 | 10:07 PM
rodimus's Avatar
Default Re: Anyone with Koni/Gc setup regret it later? (Renegade)
i just regret NOT DOING IT IN THE FIRST PLACE.
Old Jul 17, 2003 | 07:37 AM
Mires's Avatar
Default Re: Anyone with Koni/Gc setup regret it later? (George Knighton)
Just wondering, what does Gc mean?
Old Jul 17, 2003 | 10:42 PM
Art Vandeleigh's Avatar
how much does this lower the car? i have a slight problem with the exhaust slightly rubbing on the LCA...i just want to make sure i will not have the exhaust on the LCA.
Old Jul 17, 2003 | 10:48 PM
rodimus's Avatar
Default Re: Anyone with Koni/Gc setup regret it later? (Art Vandeleigh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Art Vandeleigh &raquo;</TD></TR><TR><TD CLASS="quote">how much does this lower the car? i have a slight problem with the exhaust slightly rubbing on the LCA...i just want to make sure i will not have the exhaust on the LCA.
are you forreal? you know the gc's are height adjustable, right?
Old Jul 18, 2003 | 07:32 AM
Chris N's Avatar
What are the max spring rates that off the shelf (not revalved) Koni Yellows can handle?
Chris - who has a feeling that his possible spring rates might require some revalving... 12K/8K (670.56/447.04) springs.
Old Jul 18, 2003 | 07:36 AM
.RJ's Avatar
.RJ
Default Re: Anyone with Koni/Gc setup regret it later? (Chris N)
~450-500 lbs. I ran them with 600 lb rear springs and they were fine though.
Old Jul 18, 2003 | 07:44 AM
skunkintegra's Avatar
Default Re: Anyone with Koni/Gc setup regret it later? (.RJ)
corner weighting?
i understand what it is.....
but....do shops do this? or is it a DIY??
i suppose u'd need four scales??
TIA
Old Jul 18, 2003 | 07:47 AM
Chris N's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">~450-500 lbs. I ran them with 600 lb rear springs and they were fine though.</TD></TR></TABLE>
I'm guessing 670 lb front springs wouldn't do so well then....
.RJ's Avatar
.RJ
Default Re: Anyone with Koni/Gc setup regret it later? (skunkintegra)
yes you need 4 scales and generally a shop to do it.
Its quite a pain to setup, takes about 2 hrs.
Old Jul 18, 2003 | 09:12 AM
Wai's Avatar
Wai
ProFunction/GT Motoring
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris N &raquo;</TD></TR><TR><TD CLASS="quote">What are the max spring rates that off the shelf (not revalved) Koni Yellows can handle?
Chris - who has a feeling that his possible spring rates might require some revalving... 12K/8K (670.56/447.04) springs. </TD></TR></TABLE>
Chris, Neo started a thread on this a while ago:
https://honda-tech.com/zerothread?id=190396
Old Jul 18, 2003 | 09:15 AM
py1188's Avatar
I've been trying to find a place locally here in Chicago to get my car cornerweighted, but that has proved to be quite the task.
I'm using out of the box bilsteins, and running 400/600 and have yet to experience any problems. I know you guys are curious as to the Konis, but just giving my experience
Old Jul 18, 2003 | 09:19 AM
Suprdave's Avatar
Default Re: Anyone with Koni/Gc setup regret it later? (py1188)
I have 900lbs Springs on KYBs
I'm a Drag Raceuh tho...
When they blow I'm buying Penkse's
Suprdave
Old Jul 18, 2003 | 09:20 AM
Wai's Avatar
Wai
What KYB shocks they sell in the US can handle 900 lbs springs?
Old Jul 18, 2003 | 09:22 AM
.RJ's Avatar
.RJ
Default Re: (Wai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wai &raquo;</TD></TR><TR><TD CLASS="quote">What KYB shocks they sell in the US can handle 900 lbs springs?</TD></TR></TABLE>
Probably none. I drove a car w/ KYBs and 600/800# springs and it was terrible...
Old Jul 18, 2003 | 09:38 AM
Suprdave's Avatar
Default Re: (.RJ)
You drove it on the roadcourse tho...
I had these shocks and decided just to trash them before I could justify buying new ones...
Suprdave
jxhxb
Nov 15, 2007 06:43 PM
jxhxb
Suspension & Brakes
Nov 11, 2007 12:51 AM
2ndgent3g
Suspension & Brakes
Feb 2, 2005 11:31 PM
outlaw racer
18
Apr 17, 2003 07:03 PM
