hmm noise in clutch area a little squeeky got release bearing just fixed how do i make it go away
Old Jul 16, 2003 | 08:56 AM
preluder's Avatar
Default hmm noise in clutch area a little squeeky got release bearing just fixed how do i make it go away
when i hold my foot on the clutch just a little bit the tiny squeeking noise goes away what gives? Its not like when it needed to be changed from before that noise was aweful but now theres a little squeeky noise but when i hold the bar near the clutch fluid bleeder valve that little black bar it stops? what do i do? or what went wrong?
Old Jul 16, 2003 | 08:58 AM
urbanlegend21's Avatar
New User
Default Re: hmm noise in clutch area a little squeeky got release bearing just fixed how do i make it go awa
did you grease the bearing and shaft before you put it on?
Old May 21, 2007 | 04:25 PM
jdmfanboy's Avatar
just checking in to see if you ever solved this problem.. i haver the exact same problem (99 accord, 4cyl, 5speed, 105k)
thanks,
Ryan
Old May 21, 2007 | 04:49 PM
gosu08's Avatar
as stated bring it back to your mechanic so they can lube it up and you wont hear it anymore.
Old May 21, 2007 | 05:27 PM
xluben's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gosu08 &raquo;</TD></TR><TR><TD CLASS="quote">as stated bring it back to your mechanic so they can lube it up and you wont hear it anymore.</TD></TR></TABLE>
yup, had my clutch replaced and got the same squeaking that went away with the clutched pushed in a tiny bit.
just get it lubed up!
HondaMan_TypeR
14
Jan 6, 2009 05:21 PM
mm99lude
Aug 19, 2006 07:30 AM
Cwhiteg6
May 13, 2005 09:43 AM
Cosworth
Aug 23, 2002 03:02 PM
