ex front lip install q's...
Old Jul 15, 2003 | 11:04 PM
DXturbo's Avatar
Default ex front lip install q's...
im trying to fit the ex front lip from a 95 civic on my 93 hatch but it doesnt exactly fit well. i have all the correct hardware from honda to install it but theres gaps in 3 different places. any tips....ill post pics tomorrow. thanks
Old Jul 15, 2003 | 11:12 PM
elwood's Avatar
Default Re: ex front lip install q's... (DXturbo)
Heat gun is your freind. I got mine brand new and it fit like
**** until I used some industrial bolts from Home Depot.
They wont ever rust over like the oem setup so im happy.
Old Jul 15, 2003 | 11:13 PM
authentic plusONErandy's Avatar
the fit should be perfect... there are clips that go on the bottom of the bumper and screws that go on the bottom of the lip that holds it up with a snugged fit..... i used zip-ties on mine..... the fit was great before i started scraping everywhere....it slowly got pulled out of shape and bent so there are gaps now
Old Jul 16, 2003 | 07:13 AM
DXturbo's Avatar
Default Re: (jdm1.8LSi)
i wonder wtf is wrong with mine then. it was on my friends car and it fit fine. i took all the hardware off hes bumper and switched it over to mine and it doesnt work worth ****. ill post pics tonight. any other suggestions?
Old Jul 16, 2003 | 07:16 AM
n1_ek's Avatar
* B A N N E D *
i just got some screws and drilled it straight into my bumper so it can make it harder for punks that are trying to take my lip off harder for them...
Old Jul 16, 2003 | 07:25 AM
rodrez.'s Avatar
Over time your bumper will not hold the same shape as the next guys. That's why an OEM bumper may fit excellent on one car, and like crap on the next car. Fender benders, bumps, and scrapes will "shape" your bumper over time. The heat gun idea sounds good, I'd give it a try.
Old Jul 16, 2003 | 05:00 PM
DXturbo's Avatar
Default Re: ex front lip install q's... (rodrez)
well heres the pics... do you think the heat gun will work to get it to fit better?
any other suggestions? THANKS
Old Jul 16, 2003 | 05:09 PM
moondoggy's Avatar
i had the same problems with mine when i installed it cause the lip i bought was cheap as f*ck i learned my lessons "what you paid is what you get"
basically i had to mod mine so it would fit......but i had the exact same problem as yours (it fits really bad). so i just cut and modify it to make it fit. also use a bunch of plastic screws to make them hold better.
Old Jul 17, 2003 | 07:39 AM
DXturbo's Avatar
Default Re: ex front lip install q's... (moondoggy)
damn..., thanks moondoggy. ill probablt take the bumper off to remount the lip. thanks
Old Jul 18, 2003 | 12:35 AM
Jedi_Sol's Avatar
try self tapping (self driling) screws, those helped me screw my lip onto my 93sol. Yeah it didnt fit exactly at first, but i did some cutting, test fitting, then drilling the lip right on. dont worry about the pre-made holes, just start drilling the lip on wherever you see fit because they are self drilling.
Old Jul 22, 2003 | 11:34 PM
drill two holes about 1 cm apart from eachother through the bottom of the lip and the bottom of the bumper and zip-tie the parts that are hanging
Old Jul 24, 2003 | 12:53 PM
egcivic94's Avatar
you have to strech it an bend it and if you have to try many, many self taping screws I fitted a 90 teg front lip on my wifes 93 gsr and used about 30 self tapping screws.have a friend help start from one end and drive the screws in. good luck.
faraway1215
Honda Fit
Jul 7, 2010 04:33 PM
Bright13
Aug 11, 2009 03:04 PM
defy
Sep 16, 2006 08:37 PM
Beeline
12
Aug 31, 2006 11:21 AM
FreeMyndz v.FP
Nov 27, 2001 09:31 AM
