problem adjusting coilovers
Old Jul 15, 2003 | 10:56 PM
4cdfedhatchie's Avatar
Default problem adjusting coilovers
i have adjusted my skunk 2 coilovers on tokico illuminas with no problems in the past. but, i was trying to adjust my friends' Teins SS today and had problems evening the ride height.
it seems that when i would lock one side to the desired height (for example left side), and then go to adjust the right side to the same height, the left side would be thrown off by 1/4" usually. this happens with the fronts and the rears.
Old Jul 16, 2003 | 04:34 AM
John's Avatar
New User
Default Re: problem adjusting coilovers (4cdfedhatchie)
Are you letting the suspension settle at all?
Old Jul 16, 2003 | 10:58 AM
Default Re: problem adjusting coilovers (DunReit)
how long does it take to settle?
Old Jul 16, 2003 | 11:52 AM
John's Avatar
New User
Normally, a spin around the block works for me... but I normally measure how much height I would have to add to a certain side, raise / lower the necessary height of each corner's sleeve by adjusting it. Then go around the block.
Old Jul 16, 2003 | 11:54 AM
_BEN_'s Avatar
If the car isint too out of wack drive it down the street and back. That should help settle it.
pr0gre551ve
Suspension & Brakes
May 17, 2014 02:03 PM
19josh91
14
Jun 4, 2013 08:10 AM
acmoc
28
Feb 26, 2008 06:05 AM
coreyhayman
Suspension & Brakes
Feb 16, 2007 07:15 AM
alfaaay
May 23, 2005 01:51 PM
