what trans for a 92 civ h22a swap?
the H22 uses cable shifting, so if you would like to shorten the cables so it will reach where you like it, then by all means, go ahead
you can use the H22 tranny or an H23 tranny but that would be dumb to do, but it does fit and work
you will have to use the prelude shifter cables from a 92-96 (not sure about the 5th gen's). you will also have to cut out a hole in front of your big shifter hole for the cables to come through from the tranny and hook up to your prelude shifter assembly.
o ya u better use the h22a tranny
10HBmartian
Transmission & Drivetrain
Feb 1, 2012 12:11 PM
rich
May 8, 2002 06:13 PM
