cluster lights went out... where to buy?
first one of the lights went out... then the second one went out couple of days later.... now i cant see anything on the cluster at night. i took out the two bulbs, very small and never seen anywhere have it. so im just askin you guys if this every happened to you and where you bought your light bulbs.
I went to 3 auto parts stores none had them. Then went to honda and paid $10.00 each. Spent $150.00 for 3 CRX's
On a different thread someone told me I should've tried http://www.carland.com so I'll pass that info onto you.
The small ones are Sylvania 2721...you can get them at Advance Auto Parts...they're in a green and black package thats says EUROPEAN LAMPS...not sure about the bigger ones...194's?Don't get the ones off Ebay like I almost did,they won't fit.And as for LED's,I thought about that myself...but you'd need a resistor on one leg of each LED to decrease the voltage,plus,LED's tend to project light in a very narrow path...I just went with a set of Indiglo's which are white during the day,but blue or green at night,and with the dimmer all the way down on the Indiglos,they're a nice warm red/orange color.
Glenn
Glenn
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by subgeniusdude »</TD></TR><TR><TD CLASS="quote">And as for LED's,I thought about that myself...but you'd need a resistor on one leg of each LED to decrease the voltage,plus,LED's tend to project light in a very narrow path..
Glenn</TD></TR></TABLE>
Why not just use a 12 volt LED instead of trying to put on a resistor?
I've already tried the indiglo's twice personally. After screwing up 2 clusters, that was it. Also, the indiglo's that came for a CRX had fitment issues. I won't do that ever again. I like the stock gauges fine but, I would like a brighter numbers at night.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXRageD »</TD></TR><TR><TD CLASS="quote">I've already tried the indiglo's twice personally. After screwing up 2 clusters, that was it. Also, the indiglo's that came for a CRX had fitment issues. I won't do that ever again. I like the stock gauges fine but, I would like a brighter numbers at night.</TD></TR></TABLE>
AC autotechnic
got them and fit fine the first time, removed my two bulbs, everythings great.
PM me if you want the bulbs, i can pad them in an envelope probably.
AC autotechnic
got them and fit fine the first time, removed my two bulbs, everythings great.PM me if you want the bulbs, i can pad them in an envelope probably.
cashcastellon
Mar 10, 2015 06:13 PM
