B16 pistons in my LS....how??
OK what all machining if any do i ahve to do to make B16 pistons fir my LS rods....Ive been told a lot , ive been told very little to none. WHat is that low down on thi s.
Also what gains can be esxpected. Im only doing this until i can get my 11.5 to 1 pistons. IVe been told its a decent upgrade.
THANKS
THANKS
JDM b16 pistons will make 11.5:1 in an ls block for you...p30's
anyway, there should be hardly anything machining wise, that you need to do...maybe just a basic hone...
The pistons should fit just fine, you might need to bore if you go 20 over from stock. the pistons need to be cut to fit the rod and that should be it.
can't go wrong with cams/gears, then tuning it on dyno, but if ur on tight budget just get thinner head gasket.
LS will work fine, but thinner will bump a few comp. points.
Only thing really needed is higher octane gas and maybe chipped ecu or FPR.
evilclown312
Jul 12, 2012 08:13 PM
