manual vtec engaguement?
Old Jul 15, 2003 | 07:07 PM
tek_civic's Avatar
Default manual vtec engaguement?
is there a way that i can make a switch or something to engague vtec? just need for a temporary fix.
Old Jul 15, 2003 | 07:10 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: manual vtec engaguement? (tek_civic)
to let you know there will be no fuel enrichment with a amanual switch.
the spool valve is grounded. so alls you need to do is put 12v to the black wire coming off of the spool valve.
JaeOne3345's Avatar
Default Re: manual vtec engaguement? (boostedcivicsir)
Try an MSD rpm activated switch.
Old Jul 15, 2003 | 07:16 PM
DSeriesBeeKilla's Avatar
spool valve? where is this located? show me a pic....
Old Jul 15, 2003 | 08:49 PM
tek_civic's Avatar
Default Re: manual vtec engaguement? (DSeriesBeeKilla)
so since there is no fuel enrichement whii i still see any added power from the vtec? i should have enough fuel as it is with the vortec fmu. thanks, i was wondering if it was just 12v or if it used some relay or something to give it less or more voltage.
Old Jul 15, 2003 | 09:23 PM
Filliam H. Muffman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tek_civic &raquo;</TD></TR><TR><TD CLASS="quote">so since there is no fuel enrichement whii i still see any added power from the vtec? i should have enough fuel as it is with the vortec fmu. thanks, i was wondering if it was just 12v or if it used some relay or something to give it less or more voltage.</TD></TR></TABLE>
but you still wont get that extra fuel...more power, but not as much as you should be getting.
Old Jul 16, 2003 | 07:11 AM
Mr. Badwrench
Default Re: manual vtec engaguement? (JUN EK9)
if you are boosted, i would strongly recomend against it. thats my .02 but you can do what you want.
Old Jul 16, 2003 | 07:18 AM
VRD^don's Avatar
doing this, can let you vtec any time you hit the switch. haha just like nawz.
Old Jul 16, 2003 | 05:46 PM
tek_civic's Avatar
im only boosted like 1-2 psi, so im not too worried about that doing any damage. why would you suggest against it though? its still like a more aggressive cam(basically) when i manually switch to vtec so i should be getting more power anyways, and my A/F gague says im pretty rich so maybe that will help a little too.
Old Jul 16, 2003 | 07:50 PM
Mr. Badwrench
if you are goin that far, just slit the o-ring on the spool valve it will be on all the time. if you want to melt it go ahead. if it were easy and beneficial, everyone would do it. there is no fuel enrichment and if you arent running a wide band o2 gauge or good a/f meter, i wouldnt trust that either. i melted my engine and it was green all the way.
Old Jul 16, 2003 | 10:57 PM
Frozen E's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tek_civic &raquo;</TD></TR><TR><TD CLASS="quote">im only boosted like 1-2 psi, so im not too worried about that doing any damage. why would you suggest against it though? its still like a more aggressive cam(basically) when i manually switch to vtec so i should be getting more power anyways, and my A/F gague says im pretty rich so maybe that will help a little too.</TD></TR></TABLE>
How are you only running 1-2psi? I smell one of those electric superchargers
Old Jul 16, 2003 | 10:59 PM
Patron's Avatar
What tiny *** turbo has a 2 psi wastegate?
Voodooboy520
Honda S2000
Sep 29, 2008 10:14 AM
philkehn
10
Oct 3, 2006 11:55 AM
blkhatch92
Nov 29, 2005 11:04 AM
Tatakai
14
Oct 7, 2005 07:03 PM
PhatBoy5015
11
Feb 16, 2005 06:52 PM
