WTB: EF seats, cluster with tach, new oem b series parts, etc
Old Jul 15, 2003 | 05:38 PM
w-fuck-ay's Avatar
Default WTB: EF seats, cluster with tach, new oem b series parts, etc
I am seeking
88-91 seats for my 88 hatch with all hardware etc
Guage cluster with TACH!!
new OEM for B16:
Water Pump
Head Gasket
Oil Control Orfice O ring
Intake Manifold Gasket
Exhaust Manifold Gasket
crank seal
Pcv valve
Timing Belt
Alternator Belt
Tensioner
Thermostat ds/int
Connecting Pipe O rings (2) ds/int
rear main seal ds/int
Valve cover grommets (8)
Cam Seals (2)
Oil pan gasket
Oil Pump (comes with crank seal)
Oil Filter
Oil Pick Up Gasket
Spark Plug O rings (4)
Bypass Hose (Thermostat)
and oem stuff for a 90-91 teg
Spark Plug Wires 92 - integra gsr
Upper Radiator Hose 92 - integra gsr
Lower Radiator Hose
Washer for coolant drain on block
Cap & Rotor Assembly
throttle Body Gasket
Clutch Cable
Throttle Cable
Shift linkage bushing
Old Jul 15, 2003 | 05:42 PM
b18apwr's Avatar
Default Re: WTB: EF seats, cluster with tach, new oem b series parts, etc (sdubswapper)
Might outta try the EF classifieds. It's sticky at the top of this forum.
By the way, In befo' the lizzle my nizzle.
Old Jul 15, 2003 | 07:23 PM
matt j's Avatar
Default Re: WTB: EF seats, cluster with tach, new oem b series parts, etc (d16apwr)
try a search, or check either the classifieds at the top of the page or the classifieds forum you will get your best results by a search tho
Old Jul 15, 2003 | 07:27 PM
SIRX's Avatar
first of all 95% on your list can be bought at your local Auto parts store or at Honda. If your looking for an on-line place look here http://www.hondaautomotiveparts.com/
also start a thread in the classifieds and put a link here https://honda-tech.com/zerothread?id=362113
qqhorus
Jan 18, 2013 11:22 AM
GI8U2racing
Jul 12, 2011 04:59 PM
Maui Built
Northern California (Sales)
11
May 28, 2011 11:40 PM
the g2 teg
Southeast (Sales)
11
Apr 22, 2007 08:42 PM
the g2 teg
Mar 19, 2007 12:40 PM
