Will i need a steering wheel puller for a EG... putting new steering wheel
Im going to install my snap off steering wheel this weekend and i wanna know if i need a steering wheel puller to get my stock steering wheel off. So, if nebody that knows for sure reply here... thanks.
No, it should slide right off.
If it's stuck on there prety good, just use some muscle and move the wheel back and forth to loosen it off the gear
no, i dont know what you use that wheel puller for, ive seen it in pep boys too.
take off the small plastic covers off each side of the wheel, in there is 2 Torx screws..take them out, that removes the airbag..under that in the center is a 19mm bolt.... take that out and slide the wheel right off.
i live in Si..come down sometime we'll all chill.
B
B
SuicideSlide
Sep 5, 2004 03:44 PM
... i'll get some pics up when its in..
