I DIDNT KNOW THIS COULD BREAK!!!!
Old Jul 15, 2003 | 03:25 PM
Mentat Ghola's Avatar
Default I DIDNT KNOW THIS COULD BREAK!!!!
Broke my clutch cable today. Thats right, my clutch cable. Pulling into my driveway i step on the pedal, hear a snap and it gets all loose. The loopty hook think broke off the cable. Unbelievable. Am i the only one thats broken that?
Old Jul 15, 2003 | 03:26 PM
EL Vap133's Avatar
Default Re: I DIDNT KNOW THIS COULD BREAK!!!! (Mentat Ghola)
Hasn't happened to me, do you got a stiff clutch?
Old Jul 15, 2003 | 03:27 PM
ICeDoUt's Avatar
hell no, i was in my friends car when it happened to his, pulling out of a parkin spot and it felt like we hit something when it snapped.
Old Jul 15, 2003 | 04:16 PM
mitsuman's Avatar
Default Re: I DIDNT KNOW THIS COULD BREAK!!!! (ICeDoUt)
damm, sucks
Old Jul 15, 2003 | 04:28 PM
E-AT_me's Avatar
Default Re: I DIDNT KNOW THIS COULD BREAK!!!! (mitsuman)
happened to me.. i was like a mile from my house.. made it home, though.. then bought a b series swap! hahahaa..
Old Jul 15, 2003 | 05:46 PM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
Default Re: I DIDNT KNOW THIS COULD BREAK!!!! (Rexman)
ive had that happen on my 87...driving down the road, shift into third and pop.
at least its an easy fix!
Old Jul 15, 2003 | 06:37 PM
Blaze45's Avatar
Brrraaaap!
Default Re: I DIDNT KNOW THIS COULD BREAK!!!! (fastcrxsi90)
I had it happen, easy fix. I was 6miles away from my house... 3rd gear was fun! lol
Blaze
Old Jul 15, 2003 | 07:20 PM
SIRX's Avatar
Default Re: I DIDNT KNOW THIS COULD BREAK!!!! (Blaze45)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaze45 &raquo;</TD></TR><TR><TD CLASS="quote">I had it happen, easy fix. I was 6miles away from my house... 3rd gear was fun! lol
Blaze</TD></TR></TABLE>
why was 3rd so fun? You could have just rpm matched gears and shifted that way
Old Jul 15, 2003 | 07:28 PM
SEA Hag's Avatar
Default Re: I DIDNT KNOW THIS COULD BREAK!!!! (SIRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIRX &raquo;</TD></TR><TR><TD CLASS="quote">
why was 3rd so fun? You could have just rpm matched gears and shifted that way</TD></TR></TABLE>
Has anyone ever been able to go from neutral to 1st gear without using the clutch? I can shift up or down in any other gear without the clutch, but not neutral to first from a stop. Any ideas?
Old Jul 15, 2003 | 07:29 PM
SlowHatchGrL's Avatar
I haven't broken it on my hatch (knock on wood) but I have broken it twice on my 88 Krustang!!!!!
Old Jul 15, 2003 | 07:31 PM
SIRX's Avatar
Default Re: I DIDNT KNOW THIS COULD BREAK!!!! (SEA Hag)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SEA Hag &raquo;</TD></TR><TR><TD CLASS="quote">
Has anyone ever been able to go from neutral to 1st gear without using the clutch? I can shift up or down in any other gear without the clutch, but not neutral to first from a stop. Any ideas?</TD></TR></TABLE>
ahh the fun of owning an 88 and being able to start it in gear.
Old Jul 15, 2003 | 10:19 PM
bagged89hatch's Avatar
you can put it in gear first then start the engine
Old Jul 16, 2003 | 06:10 AM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Re: I DIDNT KNOW THIS COULD BREAK!!!! (bagged89hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bagged89hatch &raquo;</TD></TR><TR><TD CLASS="quote">you can put it in gear first then start the engine </TD></TR></TABLE>
you must not have the OEM NUTRAL SAFTEY SWITCH hooked up.. its designed, so when your parked, and in 1st, you turn the key, and dont run over people, or hit walls.. lol, thats what its for.. but, i think if your idleing, and you dont' rev it, and just slam it in 1st, im sure it will go.. but yeah, you have to get those R's up pretty high, just to slide into gears..
yeah, happened to me, and a fellow local B16er.. both of us drove like a bat out of hell.. lol, in fact.. i had the police follow me home.. they litteraly made me prove the cable was broken to slide out of the ticket.. lol, now isnt' that skill? lol
Old Jul 16, 2003 | 06:12 AM
Built B16A's Avatar
Default Re: I DIDNT KNOW THIS COULD BREAK!!!! (Built B16A)
my bad.. lol, you could turn the engine off.. enter 1st gear, and then start it again.. but thats not fun.. grind away! lol
Old Jul 16, 2003 | 06:26 AM
Mr Furball's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIRX &raquo;</TD></TR><TR><TD CLASS="quote">ahh the fun of owning an 88 and being able to start it in gear. </TD></TR></TABLE>
If you start any Honda in any gear it will jump, The 88 has the feature that you do not have to push the clutch in if it is neutral, But if it's a gear the car will jump.
Old Jul 16, 2003 | 07:58 AM
B pwr's Avatar
broke mine 2 mths ago 90 crxsi, on my way to work, paying the toll, with a whole line cars behind me, made it though, yep started off in 3rd too
when i came to a light, i would go kinda slow (low rpm)so i wouldnt stall the car out, then as soon as i got green i would speed up, so i wouldnt have to stop.
Old Jul 16, 2003 | 08:01 AM
SIRX's Avatar
Default Re: I DIDNT KNOW THIS COULD BREAK!!!! (FURBALL B-16)
yes but you can start the car in gear. I've done this a lot just to show people that it can be done. Also it is a good trick to know if you are a four wheeler because if you stall the truck on a climb you can use the starter to climb the obstacle while starting the truck again. Really are some of you guys that clueless or just to inexperienced???
Old Jul 16, 2003 | 08:09 AM
SIRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Built B16A &raquo;</TD></TR><TR><TD CLASS="quote">
yeah, happened to me, and a fellow local B16er.. both of us drove like a bat out of hell.. lol, in fact.. i had the police follow me home.. they litteraly made me prove the cable was broken to slide out of the ticket.. lol, now isnt' that skill? lol</TD></TR></TABLE>
88's don't have a neutral saftey switch
Old Jul 16, 2003 | 08:11 AM
civicwagonman's Avatar
you can still start your car in gear if its got the clutch safety switch, cuase it will be in gear with the clutch pedal down and start in gear, since the cable is broke.
Old Jul 16, 2003 | 09:32 AM
PhatHardy's Avatar
Default Re: I DIDNT KNOW THIS COULD BREAK!!!! (civicwagonman)
yup, that's basically what happened to me, and i couldn't figure it out. this is when i did the swap, lol I didn't have the clutch cable nearly tight enough. Thought my tranny was seized up or something.
Old Jul 16, 2003 | 12:59 PM
Built B16A's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIRX &raquo;</TD></TR><TR><TD CLASS="quote">Really are some of you guys that clueless or just to inexperienced???</TD></TR></TABLE>
i have a lowered drag CRX... so no, i have no experiance wiht 4X4'in..
Old Jul 16, 2003 | 04:48 PM
CRXSi90's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIRX &raquo;</TD></TR><TR><TD CLASS="quote">Also it is a good trick to know if you are a four wheeler because if you stall the truck on a climb you can use the starter to climb the obstacle while starting the truck again. </TD></TR></TABLE>
...really... I wouldn't have thought you could climb an obstacle with a, what, 1/2 hp starter. I'm almost leaning to the side of not believing. If this was so, why don't we just drive around on starters all the time?
ok, maybe I'm clueless and inexperienced.
Old Jul 16, 2003 | 05:10 PM
silverCRXTC's Avatar
I second that, 88 is key
Old Jul 16, 2003 | 05:27 PM
Lamchop0000's Avatar
been there done that. get a new cable at.
http://www.hondaautomotiveparts.com/
Old Jul 16, 2003 | 07:14 PM
SIRX's Avatar
Default Re: I DIDNT KNOW THIS COULD BREAK!!!! (CRXSi90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXSi90 &raquo;</TD></TR><TR><TD CLASS="quote">
ok, maybe I'm clueless and inexperienced. </TD></TR></TABLE> north west WI you must be close to Dresser. I'd be glad to show you this at the Total Off Road Rally during Memorial weekend next year as I will be there again for the 7th year.
