how do i lubericate my slave cylinder
Old Jul 15, 2003 | 02:53 PM
01-0720's Avatar
Default how do i lubericate my slave cylinder
my clutch pedal squeks when i push it in and i was told it was my clutch slave clyinder, can somebody please tell me how to do this and if this is what is should be doin or is it something else thats makes it squek , cuz if i stick my head under the hood and sombody pushes the pedal in the sound come from the transmission area and the slave cylinder is right there , right? anyway thanks if you help
Old Jul 15, 2003 | 03:24 PM
MackSpeed-616's Avatar
Default Re: how do i lubericate my slave cylinder (01-0720)
Old Jul 15, 2003 | 03:28 PM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
lube up the pedal underneath the dash.
Old Jul 15, 2003 | 04:11 PM
intekragsr's Avatar
Default Re: (Rguy)
the squeak is because your master cylinder is going bad.
The little pushrod under the pedal going into the CMC has to be DRY! If you look under and see grease on it, its blown. Get a new one.
Old Jul 15, 2003 | 04:55 PM
Dr Pooface's Avatar
The slave cylinder is on the tranny, you can see the bleeder nipple for it to the left of the header. Pull the black rubber boot out of the tranny to expose the SC pushrod and lube it with some grease where it meets the "little arm that sticks out of the tranny" (I forget its name).
You should also check the CMC to make sure that's no tthe culprit. HTH
Edit: Big Phat R spellcheck.
Modified by Dr Pooface at 6:10 PM 7/15/2003
Old Jul 15, 2003 | 05:47 PM
BudMan's Avatar
Default Re: how do i lubericate my slave cylinder (Dr Pooface)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr Pooface &raquo;</TD></TR><TR><TD CLASS="quote">The slave cylinder is on the tranny, you can see the bleeder nipple for it to the left of the header. Pull the black rubber boot out of the tranny to expose the SC pushrod and lube it with some grease where it meets the "little arm that sticks out of the tranny" (I forget its name).
Modified by Dr Pooface at 6:10 PM 7/15/2003</TD></TR></TABLE>
It's nice to see a straight answer....but I'm still laughing my *** off after seeing the KY king photo!
Old Jul 16, 2003 | 05:38 AM
01-0720's Avatar
Default Re: how do i lubericate my slave cylinder (BudMan)
haha on the ky pic, and thanks for the straght answer, where can i get the correct grease, and if the squek goes away when i put that stuff on the slave cylinder do i still need a new master cylinder
Old Jul 16, 2003 | 07:08 AM
vtec.dc2's Avatar
it could also be springs on your clutch.. - if you're still using stock clutch.. but its probably cheaper to try to fix slave cylinder first, then look further..
Old Jul 16, 2003 | 07:14 AM
Dave-ROR's Avatar
Default Re: (intekragsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intekragsr &raquo;</TD></TR><TR><TD CLASS="quote">the squeak is because your master cylinder is going bad.
The little pushrod under the pedal going into the CMC has to be DRY! If you look under and see grease on it, its blown. Get a new one. </TD></TR></TABLE>
uhmm he said the noise is coming from near the tranny. the CMC is nowhere near the tranny.
my car has done this for.. uhm.. 45k or so. me no cares about it.
Old Jul 16, 2003 | 08:07 AM
01-0720's Avatar
Default Re: (FizzleDaKlown)
im gonna try the slave cylinder first and see if that fixes it , and my car has about 41.000 miles so is this just somthing thats needs to just be lubed and so often, and again what kind of grease should i use or is anything good
Old Jul 16, 2003 | 08:55 AM
DeL SLo's Avatar
I have the same problem, I replaced the clutch and the squeeking went away for about 10k miles then they came back. Does anyone know exactly what the cause of this problem is? This has happened to my old gsr, and both my type r and ls currently.
Born2Build
May 22, 2011 06:02 PM
Mugen112
Jul 16, 2009 07:14 PM
flatblackintegragsr
May 22, 2006 01:03 PM
siregcivic
Oct 16, 2005 07:55 PM
Chip398193
Sep 5, 2001 06:05 PM
