popping out of gears
Old Jul 15, 2003 | 01:08 PM
crx88fast's Avatar
Default popping out of gears
ok i was doing burnouts and after that my tranny started to make some rattling noises and pops out of every gear when i leave the clutch out and let off the accelerator.... im replacing the clutch this weekend but im wondering if its the bad clutch which has been slipping for a while is what is causing it to pop out of gear... ive checked my tranny a lot and made sure i still had fluid and it has always been full.... but now im also leaking some tranny fluid... does anyone know anything about any of this... if so hit me back.. thanks Jay
Old Jul 15, 2003 | 03:07 PM
Malgerus's Avatar
Default Re: popping out of gears (crx88fast)
You blew something up in the tranny. Hopefully you got enough $$$ for a new one.
Old Jul 17, 2003 | 07:02 AM
slowassgsxr750's Avatar
its your tranny fluid,same thing happened to me
Old Jul 17, 2003 | 09:23 AM
nuc79's Avatar
Default Re: popping out of gears (singleslamrex)
I bought(actually it was a trade) a 90 CRX DX a couple weeks ago, and it pops out of 2nd and 5th when I let off the gas. Can an experienced tranny builder please give us an answer? I can't believe it would just be the fluid causing this?! I know(at least I think I know) that grinding when shifting is caused by bad synchros. But I have no idea what causes a tranny to pop out of gear...
Old Jul 17, 2003 | 09:52 AM
EFSiR's Avatar
need new gear selector sleves for the gears that are poping out.
Old Jul 17, 2003 | 10:29 AM
sleeper4dr's Avatar
Default Re: popping out of gears (nuc79)
the synchro hubs/sliders have "dog" teeth on them which grab over the synchro rings when you shift into each gear. these teeth wear down and get dull just like the synchro rings do only when the sliders wear down your tranny will kick out of gear because those teeth are worn and can no longer hang on.
happened to me with my old JDM S1.
Old Jul 17, 2003 | 06:31 PM
smokey2.0's Avatar
Default Re: popping out of gears (sleeper4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeper4dr &raquo;</TD></TR><TR><TD CLASS="quote">the synchro hubs/sliders have "dog" teeth on them which grab over the synchro rings when you shift into each gear. these teeth wear down and get dull just like the synchro rings do only when the sliders wear down your tranny will kick out of gear because those teeth are worn and can no longer hang on.
happened to me with my old JDM S1.</TD></TR></TABLE>
this is OT, but did you fix the s1? if so, what synchros did you use? can you IM me that info?
Old Jul 17, 2003 | 07:48 PM
acydphryck's Avatar
Default Re: popping out of gears (Mr. S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. S &raquo;</TD></TR><TR><TD CLASS="quote">You blew something up in the tranny. Hopefully you got enough $$$ for a new one.</TD></TR></TABLE>
congrats d0nut b0y....your tranny is sh0t! might wanna sh0p for a new clutch while you're at it
Old Jul 17, 2003 | 09:13 PM
I8ayellowcrayon's Avatar
https://honda-tech.com/zerothread?id=552502
I'm too lazy to write it again
delsold16
Sep 22, 2004 07:19 AM
hdeuce
Sep 3, 2003 02:02 PM
svtec
May 20, 2003 10:21 AM
Proper
Apr 23, 2003 04:55 PM
makaveli284
Oct 2, 2002 09:53 PM
