My new dyno with 3" downpipe
Old Aug 1, 2001 | 10:04 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default My new dyno with 3" downpipe
My previous dyno was: 266.5whp 190ft./lbs @ 7.35(.5 bar)
The conditions at that time where: 60 degs.
The dyno : Dyno Jet 248
Set up: Stock motor, Rev-hard turbo kit, Tial WG, 60mm N1 exhaust, 2.5downpipe
The air Temp in the dyno was 104.5 Deg!! Damn Texas wheather!!
New Dyno run: 274whp 199ft./lbs @ 7.35 (.5bar)
Set up: Same as above but with 3" downpipe and 3" thermal
How much does 44Degs in Air Temp make on the whp difference? Also the fans they used were fans from Wal Mart and not the high power blowers that most dynos use.
Any ideas?
art
Old Aug 1, 2001 | 10:06 AM
Seraph0's Avatar
Default Re: My new dyno with 3" downpipe (Arturbo)
Old Aug 1, 2001 | 10:07 AM
Storm Shadow's Avatar
Default Re: My new dyno with 3" downpipe (MarkC)
Nice Where did you dyno at?
Old Aug 1, 2001 | 10:09 AM
bgod's Avatar
very nice!
probably would have gained another good 5whp or so with the colder weather.
i say this because n/a cars benefit greatly from colder weather on a dyno so it must be that much more so for a fi car.
Old Aug 1, 2001 | 10:10 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: My new dyno with 3" downpipe (hondaking)
Red line. I went there since I dynoed there last time and the have my old dyno runs. It was only $30 for 3 runs the 1st time and now it was $60 for 3 runs.
art
Old Aug 1, 2001 | 10:12 AM
redline's Avatar
so when do they ship?
Old Aug 1, 2001 | 10:35 AM
falcongsr's Avatar
What is this crap?
damn you turbo mafiosa types...
Old Aug 1, 2001 | 10:37 AM
VaporTrail's Avatar
New User
nice torque!!! 44 degrees is a huge difference, and the dynojet software is unable to correct between that amount of change. So, i'd expect gains to be even greater on an equal day. When you overlayed the graphs, did the boost come in any faster? When do they ship?
Old Aug 1, 2001 | 10:51 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: My new dyno with 3" downpipe (VaporTrail)
John what do you think I could have dynoed at if the conditions were the same? Im asking you since you've ran the dyno before..
I just sent out a new update.
art
[Modified by Arturbo, 2:51 PM 8/1/2001]
Old Aug 1, 2001 | 11:12 AM
VaporTrail's Avatar
New User
anything I would say would be pure speculation. I really don't know how much more, but remember for every 11 degrees intake temps drop, you pick up about 1% power. 4% of 274 would be .... a lot (I suck at math)
Old Aug 1, 2001 | 11:23 AM
dustin's Avatar
Nobody wants to donate one of those 3" downpipes to dustin for "testing purposes" ?? heheh
Dustin
Old Aug 1, 2001 | 11:31 AM
yellowbulbs's Avatar
New User
wouldnt u say alot of the power came from the 3" thermal also
that exaust did u have before?
Old Aug 1, 2001 | 11:36 AM
SIK IN DA HED's Avatar
New User
Default Re: My new dyno with 3" downpipe (yellowbulbs)
daym.. dynos are gettin more and more expensive.
u got about a 9 hp gain off a phat *** exhaust system.. not bad
get yourself a skunk2 intake manifold.. and air will flow in and out of your engine like nothing. hahah
Old Aug 1, 2001 | 11:39 AM
New User
Default Re: My new dyno with 3" downpipe (dlplayboy)
arturbo... by the way...
whut timing are you running? and what type of fuel setup?
Old Aug 1, 2001 | 11:41 AM
TypeC's Avatar
just fyi 4% of 274 is 11hp. So, given that the conditions were the same (of course we know you can never duplicate any run/condition) you would have gained 20hp from the DP and exhaust!! sounds good to me.
Old Aug 1, 2001 | 11:43 AM
VaporTrail's Avatar
New User
Default Re: My new dyno with 3" downpipe (TypeC)
that sounds on par with other exhaust dyno's I've heard too.
Old Aug 1, 2001 | 11:49 AM
HX_Guy's Avatar
I thpught dynos correct for conditions (SAE). Np matter what the temperature/onditions the software calculates what the figures would be in ideal conditions (~70 degrees I believe).
For example...when I dyno'd my car my putput was 160.0 HP and 134.7 TQ SAE corrected. Uncorrected they were 149.8 HP and 126.1 TQ.
The condition were:
97.3 Degrees 28.7-0.55 in.Hg 1000 FT
So driving around on the street...Im really only putting down 149.8HP and 126.1 TQ...but if I were to go to a location that is "ideal"..I would be putting down the SAE corrected numbers.
So bottomline..I think temperature/conditions only affect uncorrected figures...SAE corrected figures will be he same regardless of coditions.
[Modified by HX_Guy, 1:08 PM 8/1/2001]
Old Aug 1, 2001 | 11:59 AM
FAST94GSR's Avatar
New User
Default Re: My new dyno with 3" downpipe (HX_Guy)
What usually uncorrected yields more hp and corrected yields less hp, are you sure about that hx guy? That doesn't sound right.
Old Aug 1, 2001 | 12:01 PM
HX_Guy's Avatar
Default Re: My new dyno with 3" downpipe (FAST94GSR)
Yea Im sure. I think it depends on teh conditions FAST94GSR.
For example, if you dyno an its 50 degrees outside...you will lose HP when its SAE corrected..but if its hotter then the SAE figure then you will gain by corrcting.
Old Aug 1, 2001 | 12:12 PM
VaporTrail's Avatar
New User
you are incorrect. The SAE correction factor can only calculate for differences in temperature up to 9 degrees. After that, it cannot accurately correct.
Old Aug 1, 2001 | 12:17 PM
HX_Guy's Avatar
Ahh...I wasnt aware of the 9 degree part
Sorry
Old Aug 1, 2001 | 02:03 PM
redline's Avatar
And it does not work well for elevation either.
k
Old Aug 1, 2001 | 02:43 PM
JSpecwest's Avatar
New User
Default Re: My new dyno with 3" downpipe (redline)
Will it help to have a 3" downpipe if you have 2 1/2 inch exhaust piping?
Old Aug 1, 2001 | 03:05 PM
LsTurbo91's Avatar
Default Re: My new dyno with 3" downpipe (JSpecwest)
what a tease !!
Old Aug 1, 2001 | 05:08 PM
b18bvudoo's Avatar
New User
i didnt get this new update. am i on the list? thx.
