wiring problems anyone, tips tricks know how
Ok, this is what is in presently...d15 block everything else SI.....tranny ecu induction dizzy, etc etc....but it wont rev past 4k and only has 20 psi in cyl 3..prolly a messed up ring(will find out in the rebuild)...so a buddy of mine has a hf crx that he said i could have the motor out of it....any pros cons i need to know about while takeling this one...so far this hatch has had 4 motors in it...stock d16 that i got when i got it...a y8 that slung some bearings, the d15si combo with a bad ring, and now the hf.....so im tired of swappin....wanna stick with the hf/si for a while till i build up the future zc turbo.....
thanks yall
SKUNK
thanks yall
SKUNK
There should be no need to alter any wiring, I can't imagine why you would have to unless you converted it to OBD-I or II when you put that Y8 in. But if it is OBD-0 then your good to go, everything should plug right up. However the HF is a shitty *** engine with 60hp and like 8 valves. Why you would want to use that is a mystery to me.
