building the gsr
Old Jul 15, 2003 | 11:23 AM
blakacintegera's Avatar
Default building the gsr
i just got ctr pistons, fuel pressure regulator, rc 310 injectors, new head gasket, skunk2 springs and retainers, skunk2 stage 2 cams, str cam gears, and skunk2 intake mani.... before i put this all in can anybody think of something else that woud be good to do while i'm at it? i only want to tear it down once.
Old Jul 15, 2003 | 11:25 AM
RedLinin247
Guest
Posts: n/a
Default Re: building the gsr (blakacintegera)
type r cai otherwise sounds like a good setup.
Old Jul 15, 2003 | 11:39 AM
FlipboiGSR's Avatar
New User
Port and polish the head
Old Jul 15, 2003 | 11:57 AM
MooreBoost's Avatar
Fuel Pump, VAFC, Rods, Rings.
gmoore
Old Jul 15, 2003 | 12:23 PM
Rayman's Avatar
Default Re: building the gsr (tegunderpressure)
Skunk2 valves. New water pump/timing belt. Upgraded clutch. Lightened flywheel.
Old Jul 15, 2003 | 12:33 PM
Default Re: building the gsr (Rayman)
yea i've replaced the timing belt and water pump about 12000 miles ago. and the new pistons came with rings and wrist pins. do you really think a better fuel pump is needed? i also talked to one of the guys at ground zero and they tell me that the stock valves and rods in a gsr hold up pretty good for what i am running so i dunno. if anyone can get a hold of a type r tranni for me that'd be great. because along with the motor i have to also tear down my tranni and put in 2nd and 3rd gear syncros...... i appreciate the help. thanks
Old Jul 15, 2003 | 02:01 PM
can anyone tell me if its really worth spending the money on a vafc for this build? i know i could adjust my vtec but i see my friend with them and it doesnt help at all. at least on a stock motor.
Old Jul 15, 2003 | 02:07 PM
MooreBoost's Avatar
Well, if your in there, it wont take an extra two hours to put in rods, so for 300 or so bucks, you may as well. Do that and upgrade your valve train and your good for 9-10k rpm. 310's on a N/A setup will make you run rich, the VAFC can fix that. The pump is just another one of those things, if you do any sort of FI, your gonna need it, you may even need it to feed the 310s. If I were in there, Id do all that. Theres just no reason not to.
gmoore
Old Jul 15, 2003 | 02:15 PM
ragejed's Avatar
Hondata IM gasket!
Old Jul 15, 2003 | 03:38 PM
skunked's Avatar
yes you will need some sort of fuel control, Hondata or VAFC. I would stick with the stock GSR rods and the GSR pump is good enough with your setup. goodluck
Old Jul 15, 2003 | 03:54 PM
P1mpSlap's Avatar
Get ARP head bolts and rod bolts.
DavisC22
Mar 28, 2014 03:45 PM
BLUCIVICSl2
May 16, 2009 06:09 AM
2001B18C1GS-R
10
Jan 1, 2007 09:28 AM
SpoonEk253
Aug 21, 2006 09:27 AM
efit
Jun 18, 2005 11:20 AM
