Installed Integra MC and Booster, car won't seem to bleed...
Old Jul 15, 2003 | 11:08 AM
FourthGenHatch's Avatar
Default Installed Integra MC and Booster, car won't seem to bleed...
So I somehow got a Teg booster and MC in my car (was a tight *** fit). So I bled the brakes and it seems all the lines have no air. However when I start the car the pedal can be pressed to the floor but once all the way pressed it seems to stop the car. Someone told me to bleed the MC but I'm not sure what that means.
Old Jul 15, 2003 | 01:09 PM
xci_ed6's Avatar
Default Re: Installed Integra MC and Booster, car won't seem to bleed... (FourthGenHatch)
you have to bench bleed the MC before installation. I can't remember how though
-Dustin
Old Jul 15, 2003 | 01:17 PM
Default Re: Installed Integra MC and Booster, car won't seem to bleed... (Autocratic_1st_Gen)
Someone said you put it in a vice and then press the back of it. I actually did that by hand. I assume that is to get all the juice inside out? Cuz when you press the tube sticking out of the back it squirts out juice.
I actually got them to work though. What I did was use my vacuum pump and stick it on the bleeder screw and pump it, then i opened the screw, then i went inside the car and pumped the brakes with the brake pedal, that made fluid in the mc drop and soon it would come out of the screw. I have a theory that when the MC wasn't actually moved manually I was just sucking out old fluid. However once I actually pushed the pedal the MC got fluid sucked down into it.
92integraVTECgsr
25
Jul 9, 2011 02:46 AM
CourtesyBullet
Suspension & Brakes
15
Oct 22, 2008 05:46 PM
candyman206
Sep 24, 2006 08:22 PM
dng
Jul 3, 2005 09:24 PM
turbo sol
Aug 30, 2003 10:05 AM
