88crx w/ ZC need help
my car is getting no spark=no start and my clutch broke on hatch my so i really need this thing to run.
ok checked all my grounds and i replaced my coil,ignitor,cap,rotor,plugs,wires i was only getting code 10 intake air temp but now i'm getting codes 10,6,15 (iat,collant temp,ignition signal) what do you guys think i'm thinking my ecu is crap
thanks
sorry for all my **** spelling and grammar
thanks
Switch the two white wires @ the dizzy, see if it still throws code 15. Check your coolant temp sensor that its hooked up correctly. Make sure that you didnt mix up the wires @ the back of the IM for the IACV with anything else.
Good luck
Blaze
Good luck
Blaze
89dohcEF
Jul 14, 2003 06:40 PM
