84-87 1st Gen CRX
Old Jul 14, 2003 | 11:59 PM
youngwon22's Avatar
Default 84-87 1st Gen CRX
im about to buy my friends bros 86 crx and i really dont know bout 1st gen crx and i need some info on them... like suggestions on engine swap, stock engine info, etc thanx for your support
Old Jul 15, 2003 | 04:39 AM
IntegraXSi's Avatar
Well is it an Si or not?
Old Jul 15, 2003 | 05:23 AM
Ruby Civic's Avatar
Default Re: (IntegraXSi)
wwww.redpepperracing.com is a start.....but you do need to know the model as the si type is easier to mod, even with swaps, etc.
Old Jul 15, 2003 | 08:28 AM
4crx4me's Avatar
Default Re: 84-87 1st Gen CRX (youngwon22)
1st Gen CRX Si=rear wiper, sunroof.
Missing either of the above on an 86 CRX=DX or Hf
Old Jul 15, 2003 | 11:28 AM
crx12's Avatar
Default Re: 84-87 1st Gen CRX (4crx4me)
If you are doing a swap get an SI
Old Jul 15, 2003 | 11:46 AM
Davep's Avatar
86-87 integra DOHC engine will fit with oem mounts.
Old Jul 15, 2003 | 01:15 PM
xci_ed6's Avatar
Default Re: 84-87 1st Gen CRX (Davep)
d16a1 is a popular swap, or the d16a1 head will go on the stock block, lowering the compression, good for turbos. If it is a Dx a popular modification is weber side drafts, add N2O for a little boost. FI swaps suck. The Hf is bad, solid front rotors and real light suspension. A lot of work required for any swap.
-Dustin
Old Jul 15, 2003 | 01:43 PM
4crx4me's Avatar
Default Re: 84-87 1st Gen CRX (Autocratic_1st_Gen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Autocratic_1st_Gen &raquo;</TD></TR><TR><TD CLASS="quote"> A lot of work required for any swap.
-Dustin</TD></TR></TABLE>
Yeah, I agree. Need a VSS signal for VTEC. PITA
Torsion bar suspension hard to mod.
I don't think the 1G teg engine bolts in.
It requires fabrication, check http://www.hasport.com
ZC is likely the only option, IF the CRX is an Si.
If not, webers are an option.
BUT it is super light and super nimble.
Old Jul 15, 2003 | 05:30 PM
youngwon22's Avatar
thanks ppl,,, i was looking at different 85 crx and the engine is weird? it doesnt even look like d series engine its got spark on the bottom and what not,,,
Old Jul 15, 2003 | 05:33 PM
4crx4me's Avatar
Default Re: (youngwon22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by youngwon22 &raquo;</TD></TR><TR><TD CLASS="quote">thanks ppl,,, i was looking at different 85 crx and the engine is weird? it doesnt even look like d series engine its got spark on the bottom and what not,,,</TD></TR></TABLE>
Whauuh?
Clarify, please.
Old Jul 16, 2003 | 07:37 AM
youngwon22's Avatar
the 86 crx im going to get isnt an si,, not sure if Hf or Dx but is it possible to get an b16 swap on non-si crx?
Old Jul 16, 2003 | 07:43 AM
youngwon22's Avatar
Default Re: (4crx4me)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4crx4me &raquo;</TD></TR><TR><TD CLASS="quote">
Whauuh?
Clarify, please.</TD></TR></TABLE>
when i saw the engine for different 1st gen crx, the spark plugs were at where the headers should have been instead of the top of the head of the engine like other engines. And i didnt get to look at the exhaust manifold cause i couldnt find one, but any thoughts on 1st gen crx engines?
Old Jul 16, 2003 | 08:43 AM
-slow ej-'s Avatar
mayb becuz the one u were lookin at was a carburator model crx?
Old Jul 16, 2003 | 08:45 AM
-slow ej-'s Avatar
Default Re:
i raced my friend who has a stck 87 crx si (cai/e/) with the motor i got in my car (dx motor) and he took me in 3rd gotta give that up to him crx si are pretty good compared to my other friends slow *** 86 carburator crx = p
Old Jul 16, 2003 | 09:14 AM
rpr's Avatar
rpr
1 - Torsion bar suspension hard to mod.
2 - I don't think the 1G teg engine bolts in.
3 - ZC is likely the only option, IF the CRX is an Si.
1 - really? So you don't like to adjust ride height by turning a single 17mm nut? parts are out there if you are willing to look.
2 - bolts right in with teg mounts. no fabrication required.
3 - ZC is the same as 1G teg engine, in terms of swappability into a 1G CRX. And you can get carbed ZC's, so you aren't tied to the SI for a ZC.
Please know what you are talking about before posting.
Old Jul 16, 2003 | 09:58 AM
4crx4me's Avatar
Default Re: 84-87 1st Gen CRX (rpr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rpr &raquo;</TD></TR><TR><TD CLASS="quote">
Please know what you are talking about before posting.</TD></TR></TABLE>
Hey man, cut me some slack, I LOVED my 1G CRX, but I haven't owned a 1G CRX in something like 16 years. I stand CORRECTED. Do you feel better NOW.
ALL of your FINER points are most likely TRUE.
But you were MISSING my finer points.
#1 Torsion Bar is NOT as sophisticated, AS Double wishbone coilover.
and NOT AS MODABLE. Go look it UP.
#2 1G teg engine info is from http://www.hasport.com send your criticism & complaints and corrections to them, if you would really like to help 1Gener"s.
THERE ARE 2 different 1G teg engines and they are not interchangeable
with EDM or JDM ZC's. But hey you knew that already, Right EXPERT!!!!
#3 Yeah Carbed ZC's might EXIST, But how many have you seen in your LIFE?.
I was talking general practicality of things, 1st GEN expert.
Not "what's is a mere possibility"
Just remember this Swap-Master: You can put a jet aircraft engine in a
submarine IF you have enough time, money and motivation.
Have a nice day
Old Jul 16, 2003 | 10:06 AM
rpr's Avatar
rpr
Why do I even bother?
Old Jul 16, 2003 | 10:13 AM
4crx4me's Avatar
Default Re: (rpr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rpr &raquo;</TD></TR><TR><TD CLASS="quote">Why do I even bother?</TD></TR></TABLE>
Yes, why did you?
Old Jul 16, 2003 | 10:24 AM
Masta's Avatar
4crx4me, you are an idiot. You have absolutely no clue. Go away and discuss your 2G's, although I'm sure your head is so far up your ***, you can't find your car. If you are going to discuss a topic...KNOW SOMETHING ABOUT WHAT YOU ARE DISCUSSING!!!!!!!!!!!!!!!! Now go away.
Don't sweat it rpr, some ppeople are just ignorant.
D.
Old Jul 16, 2003 | 10:45 AM
4crx4me's Avatar
Default Re: (Masta)
And you so much about 1G CRX's how?
And how is anything I said in any way ignorant by your definition of the
word. Ignorant, implies not "well read".
Old Jul 16, 2003 | 10:57 AM
rpr's Avatar
rpr
All I was trying to do was point out some mistakes in what you posted. Granted, the 'know what you are posting about comment' was unnecessary, but I had just finished reading another topic about brakes locking up, and every post in there was so off base I couldn't believe it. Regardless, you came back with a bunch of stuff that was pretty harsh, and I had no wish to continue to push the issue.
Old Jul 16, 2003 | 11:00 AM
Masta's Avatar
Well, along with rpr, I am the co-founder of http://www.redpepperracing.com which is the best 1G "resource" on the net. I have helped do a d15 carb to d16 FI swap, I own an 87 CRX Si, an 85 Civic 1300 and I race rpr's 87 Civic 1500. I have seen a couple of carbed ZC's and I have also seen the ZC and the D16 in a CRX, and they bolt right in with no fab required. Now, like I said, go away. I'm sure there is a 2G owner just waiting for your mis-information.
D.
Old Jul 16, 2003 | 11:03 AM
rpr's Avatar
rpr
And also, to answer your finer points:
Yes, much.
I never said it was.
I don't have to look it up, I've done it.
I've done lots to help 1 Gen'ers.
Having owned and swapped both into a 1G CRX, yes I did know that.
3, to be exact.
Yes, that is true. It wouldn't work very well, but I do believe it's possible.
Have a nice day </TD></TR></TABLE>
I shall.
Old Jul 16, 2003 | 11:25 AM
Bluelight's Avatar
rpr and Masta,
Would a blacktop dohc ZC from a 2nd gen JDM Crx Si drop right into a 1st gen Crx Si?
Are there any fabrications or aftermarket mounts needed?
Old Jul 16, 2003 | 11:36 AM
4drEF's Avatar
Keyboard Humorist
RPR, Masta and 4crx4me,
All of you can can fight about this all you want (it's kind of entertaining in a werid way), but you all have to remember this one thing -
