93' Si Hatch
Old Jul 14, 2003 | 11:37 PM
EG6 SiR's Avatar
Default 93' Si Hatch
Will a 93' Si HB with a 95' Si HB motor(sohc vtec) pass the smog test. Im not sure if the 93' Si had the same motor. Can someone please let me know asap. Thanks!
Old Jul 14, 2003 | 11:43 PM
DiPPeD iN miLk Ej CoUpE's Avatar
Default Re: 93' Si Hatch (ortiZ32TT)
motors are the same just make sure you have all your smog stuff hooked like good cat etc...
Old Jul 14, 2003 | 11:45 PM
JDMjdawg's Avatar
Default Re: 93' Si Hatch (TooSlowTogoEF)
As long as the motor(just the block) is the same year of the car or newer, its legal and should pass. Single cams usually dont have problems passing smog, unless theres an *** load of miles on it.
Old Jul 14, 2003 | 11:50 PM
intezn's Avatar
Default Re: 93' Si Hatch (JDMjdawg)
it should
Old Jul 14, 2003 | 11:55 PM
acuracing's Avatar
It will pass smog but you have to report the new motor as being swapped into your chassis, if you want to do things the legal way.
Who Said
11
Mar 29, 2003 07:31 PM
00fbp
Nov 29, 2002 05:53 AM
