2000 civic SI Timing belt
Old Jul 14, 2003 | 09:32 PM
tegmaniac's Avatar
Default 2000 civic SI Timing belt
I changed a timing belt on an integra ls and the cams were able to stay in place by using 5 mm pin/punches through a hole in the cam holders, but I don't see anything of the sort on the b16a head. How do you keep the cams from moving so I can put the belt on at #1 TDC. Thanks
Old Jul 15, 2003 | 09:53 AM
torr's Avatar
Default Re: 2000 civic SI Timing belt (tegmaniac)
i dont think there are holes. what i did is i moved the intake cam slightly off tdc towards the firewall and then pulled the timing belt over it holding the belt tightly. by the time you're ready to put the belt on the exhaust cam pull the belt tight and the intake cam should pull itself towards tdc. takes a couple of tries, but it worked
Old Jul 15, 2003 | 10:29 AM
mmuller's Avatar
Mad Scientist
Default Re: 2000 civic SI Timing belt (torr)
yes u got holes, they are on top of the cam plates, look hard they are there...
Old Jul 15, 2003 | 07:37 PM
tegmaniac's Avatar
Default Re: 2000 civic SI Timing belt (mmuller)
Thanks for the tip. I can't believe I didn't see them. One less thing to deal with for the ls/vtec conversion
Singha83
Jun 30, 2012 11:27 PM
LSTurbo23
Jan 31, 2011 01:38 PM
pkdog167
Nov 10, 2009 10:29 PM
ReV LiMiT
Jan 25, 2005 10:11 PM
