Aftermarket fan?
Anyone know of any aftermarket electic fans that do any better of a job than the stock one. Its currently not doing all to well in ~20mph traffic in a black car in texas. Any good reccomendations would be appreciated.
if youre not doing good with the stock fan......then either the fan is toast or on its way to being toast.....or your water pump isnt pumping or you got something blocking your radiator....or your low on fluid.....
basically what im saying is that if your fan is fine then chances are the problem isnt your fan.....if you need a fan....ive got a stock one.....gimme $15 shipped...
Spal or a FAL, they will outflow the stock fan and free up room in front of your header.
EDIT: Check your hoses. Make sure they aren't ballooned, cracked or brittle. Also, check the level of your coolant.
IT only happens when im stuck in ~10 mph traffic on days that are 100+ in a black car. I dont think that it could be a problem with anything other than getting proper air flow, new hoses (ZC installed less than 6 months ago), new fluids, nothing else that would expect to be going wrong.
