DIY Front airdams?
Well I tried walmart and HD and couldnt find the edging that people used to use as a front airdamn. Anyone got a link or an idea of what else I can do..
And i know baout the roadracegear one but its more $$ thank I wish to spend!
Thanks
Thanks
I went to both... The problem is they are not a flat profile.. The bottom is round and the top has 2 perpendicular appandages from it.
Otherwise its not a flat top.. Its that rollercoaster type look
Get the professional grade lawn edging if you are going this route....it's about twice as thick as the standard stuff......about $20 will give you enough for 2 airdams.....may still need bracing though, if you want it functional.......
Limey
Limey
http://mcmaster.com
plastic sheeting. it rocks.
get at least .060 thick and pop rivet it to the front of the car.
I cant remember exactly what I bought, but search that sight and you'll find it. I think it was a 4" tall strip that was about 10 feet long.
Works much better than the garden splitter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Catch 22 »</TD></TR><TR><TD CLASS="quote">Does cost a bit more than a homemade job though.</TD></TR></TABLE>
Yes, and from my perspective of not trying to build my own at any point and just going with the RRG unit, I wonder if the total dollars spent were really less in the short run. All you guys that built one and then ended up buying a unit, if you added the time and energy and little bitty parts - which was cheaper (especially on the time part)?
Valley View Professional or Black Diamond is the good lawn edging- a bit stronger than the other stuff. I know Home Depot in WI carries it and most should. Otherwise, try a landscaping/garden store.
You could also get some sheet plastic- perhaps High Density Polyethelene or ABS which comes in sheet form in varying thickness and is somewhat flexible, depending on the thickness.
kim_2_da_chee
Feb 9, 2003 12:39 PM
