"Max boost" with 11:1 cr with stock sleeves????
Ok guys im about finish my lastest block. I need to know how much boost that my stock sleeves can handle.
setup:
f22b1 with 11:1 cr
SS valves
crower rod
wisco pistons
and all ur fuel and ignition stuff.
im currently in search for a stand alone.
setup:
f22b1 with 11:1 cr
SS valves
crower rod
wisco pistons
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NXAccordTO4B »</TD></TR><TR><TD CLASS="quote">Ok guys im about finish my lastest block. I need to know how much boost that my stock sleeves can handle.
setup:
f22b1 with 11:1 cr
SS valves
crower rod
wisco pistons
why use high compression pistons on a boosted f22b? a stock f22b can take around 8-10psi if tuned well, dont know bout your application.
setup:
f22b1 with 11:1 cr
SS valves
crower rod
wisco pistons
i had JE(8.5:1 cr) but i had fuel problems and ended up breaking a big piece of metal off my one 4 pistons. Plus i wanted to do something different
You're playing with fire, some pro's run high compression with alot of boost, but they have more resources than you and I.
I think you're asking for trouble. Id get it tuned well and put a cap on the boost at 8psi.
Mervin Fullenwider's accord ran 10:1 compression with 15 psi it had 249hp and 255lb-ft of torque with a t3/t4 turbo the block was basically stock except for a ported and polished head, valves to fit the 10:1 compression pistons and a aebs cam
I hope your not planning on running regular gas. A quick calculation for corrected compression ratio is ((Boost/14.7)+1)*CR at 8 psi your cr is about 17, im no expert but I don't think you can make that work, the highest NA cr's are like 16 and they run on the edge of disaster. As I understand once you get above 12psi you need race gas so I would think you couldn't run more then 2psi, maybe 6 on race gas. If Im wrong can someone explain the correct theory, Im still learning
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">10:1 compression with 15 psi it had 249hp and 255lb-ft of torque with a t3/t4 turbo</TD></TR></TABLE>
Really? That doesn't seem too impresive. I know all turbos are different but neidjeb (or however you spell it) here got about that on 13 psi with stock block/stock compression using a T3/T40B (or whatever comes with the f-max kit).
Properly tuned you don't need race gas to run 12 psi, but high octane is a good thing to have.
With 11 c.r. without major tuning I wouldn't go too high.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NXAccordTO4B »</TD></TR><TR><TD CLASS="quote">lol resources.... what do u mean? So in ur opinion no more than 8psi. </TD></TR></TABLE>
money
experience
more money
money to burn on trial and error
money
experience
more money
I would imaging that a turbo on high cr would have a less stable affect even under low boost than a low cr engine with high boost. I, myself have thought about it, and I'm still on the fence if I want to go down that road. It's dangerous, I've never done it, I don't really know anyone who has, but I'd be poised to see what one could do with a new alternative fuel around that's higher octane than premium gas, E85. 85% ethanol, 15% gas... check your local chevrons.
fyi, don't use E85 unless you can tune for it, otherwise you'll run too rich.
Has anyone on here ran boost with high CR?
Everyone - you are correct. for that high of a compression ratio, you'd want AT LEAST av-gas. This kinda setup has been done before, not on a F22B1 that I've seen, but on "real race engines". For this type of setup, with more than 10 psi, you'd need VERY good tuning, highly detonation resistant fuel, and you'd probably still have to rebuild after every few runs.
But anyway, I'd say about 6 psi with 93 octane and tune the **** out of it.
money.....(have spent too much already..... so whats a few extra dollars).
experience......(well ive been though about 7 motors with car).... still working on it
more money.....(money spent sooo far $30,000 in mods.....yes i broke a couple of things in the process)
money to burn..................ive been burning ever since I started.........
keep the opions coming..... i need ur input........ my motor is finish and my 5spd swap is also finish............. just killin time before i put it in...... also im trying to figure out which standalone to get.... any suggestions?
If you have the money, then by all means, go for it and make it all work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NXAccordTO4B »</TD></TR><TR><TD CLASS="quote">whats ur input on "hondata"?</TD></TR></TABLE>
Hondata is good but a rip-off. If you have a computer, EEPROM programmer, and enough time to learn how to write your own hex files, you can do the same stuff. Maybe more.
That's basically all Hondata is.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NXAccordTO4B »</TD></TR><TR><TD CLASS="quote">so if money is not the problem...... u think hondata will be better then the AEM?</TD></TR></TABLE>
no. AEM is a little more work to get right, but a far better system.
