Need to swap MAP sensor when swapping from D15 to B18A? (1991 Std Hatch)
Old Jul 14, 2003 | 10:46 AM
haggar's Avatar
Default Need to swap MAP sensor when swapping from D15 to B18A? (1991 Std Hatch)
I was reading a back issue of SCC, and they detailed a B18A install into a 1991 hatch. They said it was required to swap the gizmo with the purse solenoid, map sensor, and I think fuel pressure solenoid on it.
The CRX I bought which has a B18A already swapped in, appears to have the stock sensors.
Can anyone enlighten me a bit on this?
This newbie bows to your collective knowledge..
Thanks!
Haggar
Old Jul 14, 2003 | 11:54 AM
Blaze45's Avatar
Brrraaaap!
Default Re: Need to swap MAP sensor when swapping from D15 to B18A? (haggar)
Heres what I did. I got a TB & a map that had the MAP sensor that needed to be mounted on top. I had to extend the wires fromt he MAP so they would be long enough. Thats just what I did,
good luck
Blaze
Old Jul 14, 2003 | 08:59 PM
b16a1sirhb's Avatar
I wouldn't worry about it, I don't think it makes a difference at all.
93redcb7
12
Jun 15, 2016 02:22 AM
EFlove66
Dec 12, 2011 05:28 PM
ExVtec
Oct 16, 2008 10:48 PM
NSfit
Oct 29, 2006 12:34 PM
Soichiro-son
Aug 19, 2005 06:35 AM
