Symptons of this problem
Old Jul 14, 2003 | 09:58 AM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Symptons of this problem
Every now and then, when i drive my car and it gets hot, it seems ok but every now and then, very frequently, if i downshift to a lower gear, i would get a squeal, and if i put it back into neutral it would go away.
then if i put it back into gear, it might or might not squeal but the only way of curing the problem would be going into neutral and then putting it back into gear to hope that it doesn't squeal
what could be the problem
clutch? bearings?
Old Jul 14, 2003 | 10:45 AM
MugenHonda's Avatar
Default Re: Symptons of this problem (MugenHonda)
ttt cuz it is annoying the hell out of me
Old Jul 14, 2003 | 12:18 PM
91hondacrx's Avatar
The only things that usually squell in the engine bay are belts, check your alternator belt, if it has cracks and is loose then you should try replacing that. I would try that first and go from there.
Matt
Gamblor
Transmission & Drivetrain
Jun 29, 2017 09:09 PM
Villenurve
Oct 12, 2007 09:58 AM
dude100
Honda Motorcycles
Oct 1, 2004 08:10 PM
MPH
Jun 11, 2002 10:57 AM
