ITR shakes when A/C is on, whats the problem?
Old Jul 14, 2003 | 06:29 AM
Type_Rydah's Avatar
Default ITR shakes when A/C is on, whats the problem?
ITR shakes when A/C is on, whats the problem? please help!
Old Jul 14, 2003 | 06:37 AM
vtec.dc2's Avatar
Default Re: ITR shakes when A/C is on, whats the problem? (Type_Rydah)
maybe your car is at low rpm.. stock ecu doesn't always raise rpm when a/c is turned on..
Old Jul 14, 2003 | 06:49 AM
ITR764's Avatar
Default Re: ITR shakes when A/C is on, whats the problem? (vtec.dc2)
mine makes some kind of noise that sounds like the clutch is chattering? when i press the clutch in it stops???
Old Jul 14, 2003 | 06:56 AM
Nishant's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 &raquo;</TD></TR><TR><TD CLASS="quote">maybe your car is at low rpm.. stock ecu doesn't always raise rpm when a/c is turned on.. </TD></TR></TABLE>
thats true...my idle rpm drops when i turn on the ac. you just gotta learn how to adjust aka give it just a little bit more gas. This only happens when you turn on the ac, after you run it a bit, the idle rpm goes back to normal.
Old Jul 14, 2003 | 06:57 AM
vtec.dc2's Avatar
Default Re: ITR shakes when A/C is on, whats the problem? (ITR764)
yeah.. same here..
Old Jul 14, 2003 | 10:48 PM
kkim's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type_Rydah &raquo;</TD></TR><TR><TD CLASS="quote">ITR shakes when A/C is on, whats the problem? please help! </TD></TR></TABLE>
does the idle rpm go up or down when the a/c is on?
Old Jul 14, 2003 | 11:06 PM
Chris N's Avatar
Default Re: ITR shakes when A/C is on, whats the problem? (kkim)
I'm guessing it is robbing power from the engine... and with such a small engine, that causes a considerable loss. Happens in my car too.
Old Jul 15, 2003 | 01:17 AM
Resident Evo's Avatar
Default Re: ITR shakes when A/C is on, whats the problem? (Chris N)
A/C is like a kill switch for our little Honda/Acura's
Old Jul 15, 2003 | 03:38 AM
jond's Avatar
Default Re: ITR shakes when A/C is on, whats the problem? (EBP-Si)
Mine sounds like the engine has spun a bearing when I turn on the AC. I get a kind of knocking sound.
Anyone else hopefully
Old Jul 19, 2003 | 02:50 PM
Jeffroman's Avatar
yeah same here, 2000 gs-r
Old Jul 19, 2003 | 05:05 PM
p nut's Avatar
Default Re: (Jeffroman)
Yeah, also make sure you give it more gas when taking off so you don't stall. It happened to me 3-4 times when I first got the car. Man, that was EMBARASSING!
Old Jul 19, 2003 | 05:15 PM
(__________)'s Avatar
Default Re: (Paul55100)
AC kills our little cars, that is why I dont have it
Old Jul 19, 2003 | 05:42 PM
Moonbus's Avatar
Default Re: (steves98itr247)
I agree!! After I turn on the AC, I can really feel the lose in power!!
drg1989
Mar 15, 2008 01:40 PM
gray_civic_coupe
Nov 25, 2005 04:57 AM
Addicted2Racing
Sep 15, 2005 07:46 AM
JDM_ROokie
May 30, 2005 08:35 PM
TypeRPaul
May 21, 2004 05:43 PM
