b20 91 hb si
Old Jul 14, 2003 | 06:28 AM
Dorifto13B-T's Avatar
Default b20 91 hb si
Im gunna be doing a b20/vtec swap in my hatch. Ive been readin alot about it i start next sunday. my question is what vtec head to use and ecu. im usun and ls tranny. but the head does it have to be obd0 such as a sir head or can i use any and get the wire harness convertor. like say if i was to use a ITR head id have to get a conversion correct? what ecu would i use for the b16 had and then for the ITR head. oh and if i go with the b16 head which cams would be better CTR or ITR. thanks yall hope fully i can get this resolve before sunday...
Old Jul 14, 2003 | 08:31 AM
Charlie Moua's Avatar
Default Re: b20 91 hb si (wyt r1ce)
well i do not belive that you will even start this project on Sunday.
You said you have been doing a lot of reading... do more reading!
your car is OBD-0. You can stay with that or convert over to OBD1
the choice is up to you.
The head does not matter when choosing what OBD to run. What matters is the injectors, harness and distributor. So you can use a 2000 ITR, 99 si head, 94 gsr head or anything B-seires vtec head. do you understand ?
the ecu is going to have to be base on if you want to stay OBD-0 or convert over to OBD-1. If you choose to stay OBD-0 get the PR3 ecu from the 1st gen b16. if you go with OBD-1 then you have more options like chipped p28, GSR, B16, ITR ecu.
CTR cams will make more power over ITR cams, but 2000-2001 ITR cams are the same spec as CTR cams though.
Old Jul 14, 2003 | 08:39 AM
Default Re: b20 91 hb si (Charlie Moua)
Got any links to where i can purchase a conversion harness to obd1 or if its just a matter of rewiring know of where some instructions i can get um at. I think i understand lol. thanks.
oh im not runnin vtec for about a week i just need to put the motor in there so i can get the body work done first.
Old Jul 14, 2003 | 09:08 AM
Found some good info on odb0-odb1 really informative lemme know what you think if this sounds all good then thats the rout im gunna go ill. What harness should i use the b20 harness or or a b16 harness
http://www.korossy.org/honda/harness.html
Old Jul 14, 2003 | 03:11 PM
ttt
Old Jul 15, 2003 | 04:36 AM
for the conversion harness contact a fellow Honda-tech memeber her by the names of (Blown90hatcH) just IM him or do search in the CREATOR box and you'll see what he offers, I think like 50+ people here have bought from him.
well if your only going to run B20 OBD-1 right now then just get the correct injectors and distributor and you should be set. Also get a LS manifold too.
Old Jul 15, 2003 | 06:09 AM
ight cool. i check into that theres a dude by me with one for 30. as for the injectors and distributor u mean stock b20 injectors and disributor ?
Old Jul 15, 2003 | 07:15 AM
powerofdreams8's Avatar
No, you need injectors and distributor according to what OBD you will be running. So if you are gonna run the b20 alone for a while and keep your OBD0 ecu than you need OBD0 distributor and injectors. You should get the b20 motor and use an OBD0 LS manifold/injectors/distributor.
Old Jul 15, 2003 | 08:10 AM
Default Re: b20 91 hb si (powerofdreams8)
what if i used b16 intake injections and distributor. would ls run better for right now or the b16.
Old Jul 15, 2003 | 08:36 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wyt r1ce &raquo;</TD></TR><TR><TD CLASS="quote">what if i used b16 intake injections and distributor. would ls run better for right now or the b16. </TD></TR></TABLE>
Well a B16a intake manifold will not bolt on to you B20 head. (since your going just B20 for now). you will have to get a LS intake manifold or if you want..get the skunk2 intake manifold. So what OBD are you choosing 0 or 1? we need to know this so that we can help you out.
Old Jul 15, 2003 | 09:10 AM
Mr Furball's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Charlie Moua &raquo;</TD></TR><TR><TD CLASS="quote">CTR cams will make more power over ITR cams, but 2000-2001 ITR cams are the same spec as CTR cams though. </TD></TR></TABLE>
I thought the CTR cams were 3 degrees more duration then the ITR, It's a mute difference and I don't think that the CTR cams are worth the money that people sell them for but I did not think that they were the same spec.
Old Jul 15, 2003 | 08:29 PM
i guess im gunna go obd1 seems easier to get ****. gimme a list of what i need.
Ls ob1 injectors
" " distributor
" " intake mani
" " ecu
obd0-obd1 harness
anything else....
Old Jul 16, 2003 | 11:59 AM
ttt
Old Jul 16, 2003 | 08:16 PM
Old Jul 16, 2003 | 08:45 PM
sleeepy808's Avatar
i would convert the car from obd-0 to obd-1. i had a 99 b16a head on my ls/vtec in my 90 hatch
Old Jul 16, 2003 | 08:46 PM
Default Re: (sleeepy808)
how was it
Old Jul 16, 2003 | 09:29 PM
sleeepy808's Avatar
depsite being assembled wrong, it pulled hard. did a 13.0 here in vegas with it with a lot of room for improvement. but at the same time i have a stock itr motor was able to do a 13.3 with the same chassis, ef9, and full interior this time
Old Jul 17, 2003 | 04:42 AM
Default Re: b20 91 hb si (FURBALL B-16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FURBALL B-16 &raquo;</TD></TR><TR><TD CLASS="quote">
I thought the CTR cams were 3 degrees more duration then the ITR, It's a mute difference and I don't think that the CTR cams are worth the money that people sell them for but I did not think that they were the same spec. </TD></TR></TABLE>
well i know that the 96-98 itr cams have different specs, but I THINK the 99-2001 itr cams have the same intake cam spec as the CTR now. The exhust cams has always been the same on both. someone correct me if I'm wrong.. I'm too lazy to do search right now
Old Jul 17, 2003 | 09:32 AM
sleeepy808's Avatar
i never heard of there being different specs on itr or ctr cams for different years. i know that the exaust cams are the same, but the ctr have a slighty more aggresive intake cam than the itr
Old Jul 17, 2003 | 11:22 AM
guy told me just use a ls ecu with the stock motor and ls tranny. he said itd be fine. what do yall think
Old Jul 18, 2003 | 03:30 AM
Default Re: (wyt r1ce)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wyt r1ce &raquo;</TD></TR><TR><TD CLASS="quote">guy told me just use a ls ecu with the stock motor and ls tranny. he said itd be fine. what do yall think</TD></TR></TABLE>
yup hes right. Also think about getting a FPR and bump it up 1-2psi for more fuel since the B20 is bigger than the 81mm LS motors to just compensate for more fuel through the entire powerband.
Old Jul 18, 2003 | 07:54 AM
Default Re: (Charlie Moua)
FPR? lol im learnin still lol
edit: nvm fuel pressure reg. lol took me amin to think
Modified by wyt r1ce at 6:15 PM 7/18/2003
Old Jul 18, 2003 | 10:30 AM
fuel pressure regulator!
most PR4 (obd1 LS ecu) run at a set fuel pressure of 38psi.
Because your putting a B20 in with 0.2 more liters it will need more fuel to run more efficently. Set the FPR at about 40-42psi and your good to go.
You don't need the FPR for the motor to run. It will run fine at 38psi, your motor will just run leaner, which is not good in the long run.
Old Jul 18, 2003 | 10:38 AM
i love you man haa thanks for all this help lol yo where should i pick up some axels from or just get som bseries ones stock? im thinkin they wont fit pick some up from hasport or the classifieds..
Old Jul 18, 2003 | 10:42 AM
Malgerus's Avatar
You want 00-01 ITR Cams.
