Good cam upgrade for the type-R?
Old Jul 14, 2003 | 05:14 AM
charjacq's Avatar
New User
Default Good cam upgrade for the type-R?
What would be a good cam upgrade for the type-R? This is mostly for street performance. I don't need the absolute best, just a good upgrade. I do not have the need for expensive jun cams. Has there been a review of the different cams? Also, which cams could be used with the stock type-R valve springs?
Old Jul 14, 2003 | 05:33 AM
TodaTeg's Avatar
You could go Toda A's, or you could pick up a set of Crane cams. The Toda has a nice price tag. but either one will retain the stock ITR valve springs and will give you good preformance.
Old Jul 14, 2003 | 05:34 AM
Hybrid ctr's Avatar
Default Re: (TodaTeg)
Toda A's
Skunk2 Stage 1
they are comparable, and you can use stock valvetrain
Old Jul 14, 2003 | 06:03 AM
charjacq's Avatar
New User
Default Re: (Hybrid ctr)
What are the power figures of these in comparison to other cams?
Old Jul 14, 2003 | 06:08 AM
Hybrid ctr's Avatar
Default Re: (charjacq)
can you be more specific
Old Jul 14, 2003 | 06:15 AM
charjacq's Avatar
New User
Sorry, I meant, what the power increase when well tuned would these give in comparision to each other.
Old Jul 14, 2003 | 06:19 AM
Ex-ITR5874's Avatar
Default Re: Good cam upgrade for the type-R? (charjacq)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by charjacq &raquo;</TD></TR><TR><TD CLASS="quote">What would be a good cam upgrade for the type-R? This is mostly for street performance. I don't need the absolute best, just a good upgrade. I do not have the need for expensive jun cams. Has there been a review of the different cams? Also, which cams could be used with the stock type-R valve springs?</TD></TR></TABLE>
Jun stage 2 only intake cam.... That`s half the price for performance..
I`m sure that if you spend some time for a search, you`ll be satisfied with the info you`ll find.
Imho a cam upgrade ist crap. To much money for just a few hp... Go turbo or charger if you like to make serious gains...
Old Jul 14, 2003 | 06:55 AM
vtec.dc2's Avatar
Default Re: Good cam upgrade for the type-R? (ITR5874)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR5874 &raquo;</TD></TR><TR><TD CLASS="quote">
i agree, in the long run it will be almost as much money n/a and more money if you to get n/a first and switch turbo as i did.. it will be faster.. and its so easy to get hp..
if not, then keep it stock, its so little difference.. really.. unless you're going to make the most of n/a setup..
Old Jul 14, 2003 | 07:35 AM
ScaleExtric's Avatar
Default Re: Good cam upgrade for the type-R? (vtec.dc2)
skunk 2 stage 2's
Old Jul 14, 2003 | 08:15 AM
GokuSSJ4's Avatar
Default Re: Good cam upgrade for the type-R? (ScaleExtric)
Toda A , Skunk stage 1 or jun stage 1 and some good tuning
Old Jul 14, 2003 | 08:42 AM
Chris N's Avatar
I agree. With some tuning, there's a lot of power to be made for half the price of Toda A's or Skunk 2 Stage I cams. Mad midrange. I have a dyno that another board member forwarded on to me. Impressive indeed.
Old Jul 14, 2003 | 08:45 AM
Ex-ITR5874's Avatar
Default Re: Good cam upgrade for the type-R? (Chris N)
And don`t forget: The JUN cams are of awesome quality.... Just for peace of mind..
Old Jul 14, 2003 | 02:21 PM
snake01's Avatar
I made more power with my stock cams then when I did with toda A's
Old Jul 14, 2003 | 02:30 PM
fuck honda-tech's Avatar
Default Re: Good cam upgrade for the type-R? (snake01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snake01 &raquo;</TD></TR><TR><TD CLASS="quote">I made more power with my stock cams then when I did with toda A's</TD></TR></TABLE>thats not susprising because ctr cams are suppose to be better than those
Old Jul 14, 2003 | 03:42 PM
DouLik's Avatar
i'd go with skunk 2's lots of people are using them
but how bout ef-1 cams? m21 cams rquire no valvetrain upgrades while m22 and over will require an upgraded valve springs
pm me if you are intersted
Old Jul 14, 2003 | 04:15 PM
Spoond TEG's Avatar
Default Re: (beatdownvictim)
Most inexexpensive upgrade would be CTR cams at 500 a pair NEW you can't beat the bang for the buck.
I chose to go with Spoon cams, but these did require a Valve Spring upgrade so might not be your alley. Most mild cams can be run on the Stock setup but you have to note where the cams are supposed to give the best advantage.
Old Jul 14, 2003 | 04:26 PM
Rob Dizzle's Avatar
Default Re: (Spoond TEG)
well, why dont u post what kinda setup you have.
if you want more power, cams might not be the best for you in every situation.
unless this guy has an pre-98 itr cam, the ctr cam=itr cam
Old Jul 14, 2003 | 04:27 PM
Hooch'n's Avatar
Default Re: (Bob-DC2)
IM Len: KIllers.....hahah
Toda B's are nice.......seriously
Old Jul 14, 2003 | 04:35 PM
P1mpSlap's Avatar
Killers
Si Jeff
Sep 27, 2012 07:40 AM
gsrwpower
Mar 21, 2006 05:38 PM
conceptEG
Feb 26, 2004 12:48 PM
d!zZy
Apr 18, 2003 09:47 PM
Short_Shifter
Feb 6, 2002 01:30 PM
