Rotton / Broken seat mount points
My SiR is stripped bare and almost ready to be painted. I am going to have to get a couple of patches in the floorpan welded as it has some slight corrosion in places.
My pasenger seat mount points (the 2 rear ones in the floorpan) have corroded and the thread has fallen out. Has this happened to any of you and what did you do to fix the problem?
Thanks in advance
Mark
Modified by markleavey at 2:10 PM 7/14/2003
Thanks in advance
Mark
Sadly this just happened to me recently....Instead the Threads ripped up thru the floor when installing my New Seats....They werent even Hand tight yet
I am going to pull the carpet up and have New Sheet Metal welded over top with the same Thread/Pitch Nut as factory. You should be able to pull the body Plug from underneath the car and have the Nut retacked back on.
Damn Old cars
Just so you know your not alone!
Later,
Mike
'88 CRX "ZCREX"
'99 S-10 Xtreme
I am going to pull the carpet up and have New Sheet Metal welded over top with the same Thread/Pitch Nut as factory. You should be able to pull the body Plug from underneath the car and have the Nut retacked back on.Damn Old cars
Later,
Mike
'88 CRX "ZCREX"
'99 S-10 Xtreme
Nisif
May 24, 2007 09:22 PM
Another Drew
33
Jan 10, 2006 06:45 AM
Want2race
Apr 30, 2003 01:17 PM
