skunk2 spring rates
They used to make a Civic specific (300/400) and an Integra specific (400/500). Now they just make a 400/500.
These are pretty good all around rates for street and autocross.
My "Integra" Skunkworks kit was supplied with 7.25.006 and 7.25.008 springs. These numbers are length, inner diameter (2.5") and the kg/mm rates. This translate to 335 lb/in and 447 lb/in spring rates, respectively.
For math conversion: kg/mm * 56 = lb/in
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsirnj »</TD></TR><TR><TD CLASS="quote">My "Integra" Skunkworks kit was supplied with 7.25.006 and 7.25.008 springs. These numbers are length, inner diameter (2.5") and the kg/mm rates. This translate to 335 lb/in and 447 lb/in spring rates, respectively.
For math conversion: kg/mm * 56 = lb/in</TD></TR></TABLE>
you got the spring rate right on the money. those spring rate was
offered for a civic. integra were firmer. but i think the civic spring rates are a lot better
for comfort/handling.
you got the spring rate right on the money. those spring rate wasoffered for a civic. integra were firmer. but i think the civic spring rates are a lot better
Are you sure they are around 450f? I have the crx skunk2 kit on my car now and the front doesn't feel nearly as stiff as my old neuspeed race, which I believe were 450f(correct me if I'm wrong). Well at any rate, from these responses, I ordered the wrong set because I was hoping to get a stiffer ride than my old neuspeeds. Thanks for your replies guys. I guess I could always order a pair of 700.250.010 for the front, to match the integ kit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goofball123321 »</TD></TR><TR><TD CLASS="quote">Are you sure they are around 450f? I have the crx skunk2 kit on my car now and the front doesn't feel nearly as stiff as my old neuspeed race, which I believe were 450f(correct me if I'm wrong). Well at any rate, from these responses, I ordered the wrong set because I was hoping to get a stiffer ride than my old neuspeeds. Thanks for your replies guys. I guess I could always order a pair of 700.250.010 for the front, to match the integ kit. </TD></TR></TABLE>
Actually, I sent an email to Neuspeed about the race springs for the CRX, asking what their "working" rate was...they told me 575f/525r, so they're pretty stiff little buggers if that's the case. The sports, according to Neuspeed, are rated at 275f/225r, and compared to the skunk2's that's pretty soft.
Alex
Alex
Hey, this link has alot of spring rates for civics listed... http://forums.clubsi.com/showf...art=1 Rick
these site are more accurate:
http://php.indiana.edu/~bchang....html
http://sales.hondatwincam.com/modelspecs.htm
http://www.anzwers.org/trade/h....html
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jc836 »</TD></TR><TR><TD CLASS="quote"> We "custom" ordered these and the box says Integra on it and not CRX. </TD></TR></TABLE>
Hahaha, why didn't you just say you ordered the Integra ones?
The kit I have on my CRX is rated at 400f/500r. I ordered the springs from Ultra Performance this way. Skunk2 will ship the rates you want. This setup is for a dedicated race car versus a street/track/autocross car. The rating is printed on the spring along with the diameter and length. It is the last number that tells you the rate.
sporkcrx
Oct 23, 2002 07:13 PM
