Throttle pressure sensor?
Old Jul 13, 2003 | 09:28 PM
yellowmonkeyboy's Avatar
Default Throttle pressure sensor?
what does it do?
will car work okay with one that does not function?
Old Jul 13, 2003 | 09:34 PM
ProJectCvic's Avatar
Default Re: Throttle pressure sensor? (yellowmonkeyboy)
i think you mean tps= throttle position sensor?? if so...like sex, you can't live without it it tell you frankly the postion of how open or close the throttle is
Old Jul 13, 2003 | 09:36 PM
Turbogixxer's Avatar
You mean throttle POSITION sensor. It tells the ECU where and how much the throttle blade moves. Without it, the ECU does not know where the throttle is. Is equals very poor throttle response (duh) and a ranging idle. The car will run but with the things that I told you about.
Old Jul 14, 2003 | 10:11 AM
Charlie Moua's Avatar
Default Re: Throttle pressure sensor? (turbogixxer)
how do you know if it's bad? can you take if off and test it with some sort of volt meter to ensure that it's correctly working? how much does a new one normally cost?
ALL honda/acura TPS sensors are inter-change able right
Old Jul 14, 2003 | 10:45 AM
Default Re: Throttle pressure sensor? (Charlie Moua)
You leave it on the car and start the car. grab a voltmeter and test the Red/blue wire. It should be .45 volts at idle and 4.5 volts at WOT. If not try adjusting it, if that does not work then you will have to replace it.
Old Jul 14, 2003 | 01:50 PM
AussieK24's Avatar
Hehehe DON'T check for WOT with engine running hehehe
Old Jul 14, 2003 | 02:38 PM
Default Re: Throttle pressure sensor? (AussieB20vtec)
Sorry, I mean with the key in the Run/On position. Sorry about that
Old Jul 14, 2003 | 10:03 PM
how much does one usually go for? tps interchangeable bettween honda cars?
Old Jul 14, 2003 | 10:28 PM
4crx4me's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellowmonkeyboy &raquo;</TD></TR><TR><TD CLASS="quote">how much does one usually go for? tps interchangeable bettween honda cars?</TD></TR></TABLE>
Yeah, All Honda MPFI-TPS's are interchangeable.
Get one from junkyard=$5-10
Honda=$100+ I think?
Old Jul 15, 2003 | 06:04 AM
B18C5-EH2's Avatar
Former Moderator
Loved
The engine will run like **** if a T.p sensor is unplugged, defective, or broken.
The T.P sensor is NOT available from the Honda dealer unless you buy a complete throttle body, which is a total rip-off.
What's the cheap and easy solution?
Well at first clance the T.P sensor looks to be riveted to your TB. Those are actually headless screws that can be removed if you grind a slot in them and unscrew them as you would any normal screw. A punch works too.
Once you unscrew the old T.P sensor, remove another one from any late model Honda TB and just find normal screws that fit in the threads and screw the "new" one in.
Broken T.P sensors are VERY common on JDM engines and the T.P can be easily broken when lowering the engine into the car that you're swapping into.
Hope that helps!
Old Jul 15, 2003 | 11:41 AM
preluder's Avatar
Default Re: Throttle pressure sensor? (B18C5-EH2)
go to a junkyard
CWT
Honda Civic (2001 - 2005)
Oct 14, 2008 05:10 AM
nutball72
Nov 11, 2006 07:14 PM
GSRcivicGSR
Dec 20, 2004 04:29 AM
GsRwHiTe
Mar 22, 2004 03:08 PM
Redsim
Jun 11, 2003 09:37 PM
