Good, safe cam setting for this setup:
Old Jul 13, 2003 | 07:29 PM
Beave0101's Avatar
Default Good, safe cam setting for this setup:
(99 SI, B16A2)
Head removed, and skunk2 valvetrain installed.
*Spoon 2 layer headgasket
*Milled .020
*Skunk2 Stage II camshafts
________________________
I've asked before, and for every .01 you mill, you retard the cams -1 degree, and the crankshaft -2 degrees ?
will be running this setup for about three weeks before i get the $$$ for hondata.
thanks guys
Old Jul 13, 2003 | 08:35 PM
skribblah's Avatar
Default Re: Good, safe cam setting for this setup: (Beave0101)
1) dont mill the head please. too many possible problems for somthign so little.
2) s2s2 = yummmm
Old Jul 13, 2003 | 09:19 PM
Beave0101's Avatar
Default Re: Good, safe cam setting for this setup: (skribblah)
too many problems if taking to a crap shop and a hack job done of it. and since it's not a serious amount being taken off, and the pistons and bottom end will be stock forever, and although it can't be reversed, a thicker headgasket CAN be put on....and this has already been done to the head.
___
back to the original question.....
Old Jul 13, 2003 | 09:20 PM
b19coupe's Avatar
Your best bet is to clay the motor, but with stock pistons, you should be fine as far as valve to piston clearance at 0,0. The thing is, claying the motor will tell you how much cam timing adjustment you have before valve to piston contact.
Old Jul 14, 2003 | 05:38 AM
Mr Hammond's Avatar
a/k/a Jomo
0,0. Clay the motor find your limits and remember them when you go tune the car.
Old Jul 14, 2003 | 03:08 PM
Beave0101's Avatar
Default Re: Good, safe cam setting for this setup: (Mr Milano)
so really no good way to run this car without claying the motor ?
granted i want to do things right, but i'm in over my head on the work i'm doing now. i'll look more into it, but if there is any rule of thumb for the cam settings......hmmm
Old Jul 15, 2003 | 05:25 PM
Beave0101's Avatar
yfz
Sep 18, 2009 08:46 PM
94IntegraLs04
13
May 31, 2006 06:57 PM
L_moto_crx
Aug 9, 2005 09:14 AM
crxste
Apr 14, 2005 07:23 AM
flybert
15
Nov 15, 2004 02:26 PM
