Paint chipping in engine bay (pics inside)
Old Jul 13, 2003 | 06:58 PM
2qwik2nv's Avatar
Default Paint chipping in engine bay (pics inside)
Today, I noticed some chipping on my shock towers. Here are the pics. Current set-up is: Stock rim w/205/50/15 Falken Azenis, Zeal B6 Hard Setup (F:12K R:7K)
Does anyone have any idea why this may be happening? I also checked with another '01 R and he is experiencing the same issue. From what I can see, there is nothing which could be rubbing against the paint to chip it.
Any help or suggestions would be appreciated.
Here are the pics.
The gap between the tire and body is actually 1/2 inch or so.
Old Jul 13, 2003 | 07:01 PM
bb6's Avatar
bb6
Default Re: Paint chipping in engine bay (2qwik2nv)
Do you have a camber kit?
Old Jul 13, 2003 | 07:25 PM
Denny's Avatar
Default Re: Paint chipping in engine bay (bb6)
i guess its time to repaint your whole car
Old Jul 13, 2003 | 07:26 PM
Edwin's Avatar
Too much stress on the frame by the Zeals?
Old Jul 13, 2003 | 07:34 PM
ITR-Spoon's Avatar
i have the same problem on mine car, same place.
Old Jul 13, 2003 | 07:35 PM
garagespecial
Guest
Posts: n/a
Default Re: Paint chipping in engine bay (Edwin)
rock ?
Old Jul 13, 2003 | 08:13 PM
kkim's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb6 &raquo;</TD></TR><TR><TD CLASS="quote">Do you have a camber kit?</TD></TR></TABLE>
well... do you?
Old Jul 13, 2003 | 11:52 PM
turbospool's Avatar
Default Re: Paint chipping in engine bay (kkim)
i have the skunk2 camber kit on my integra and i have the same thing. its the upper control A arm hitting the shock towers thus craking the paint. something to live with...
Old Jul 14, 2003 | 02:01 AM
PoW3l2BaN's Avatar
Default Re: Paint chipping in engine bay (turbospool)
Turbospool is right. I have the same problem. It happened from bottoming out. The upper A arm reached the shock tower and dents it.
Old Jul 14, 2003 | 05:06 AM
2qwik2nv's Avatar
Sorry, I posted this just before I went to bed. I do have a camber kit. Skunk2 and my camber settings are stock, I believe it's -0.5
Old Jul 14, 2003 | 05:09 AM
2qwik2nv's Avatar
Default Re: Paint chipping in engine bay (PoW3l2BaN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PoW3l2BaN &raquo;</TD></TR><TR><TD CLASS="quote">Turbospool is right. I have the same problem. It happened from bottoming out. The upper A arm reached the shock tower and dents it. </TD></TR></TABLE>
Is that due to the type of camber kit, or would another camber kit remedy this problem? Would the upper control arm bottoming out cause undue stress in the long run? Do I need to raise the car up a little to avoid this happening?
Many thanks guys!!
Old Jul 14, 2003 | 05:44 AM
Track rat's Avatar
Your ride height is set too low. Raise your ride height and/or your spring rates!
Did you remove the bump stops? If so, put them back in!
Old Jul 14, 2003 | 05:54 AM
2qwik2nv's Avatar
Default Re: Paint chipping in engine bay (Track rat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Track rat &raquo;</TD></TR><TR><TD CLASS="quote">Your ride height is set too low. Raise your ride height and/or your spring rates!
Did you remove the bump stops? If so, put them back in!</TD></TR></TABLE>
Bump stops are still installed, how much should it be raised? 1/2" Thanks Track rat!!
Old Jul 14, 2003 | 06:02 AM
ITR764's Avatar
yeap, as stated above, your too low or need higher rates.
Old Jul 14, 2003 | 06:28 AM
Track rat's Avatar
Default Re: Paint chipping in engine bay (ITR764)
How much to raise? Depends. With higher rates, you may not have to raise it. With the same rates, just raise it until the UCAs stop smacking your towers.
Old Jul 14, 2003 | 08:04 AM
azn98R's Avatar
I jave the same problem too.. and I had a camber kit aswell... hmmm
Old Jul 14, 2003 | 11:31 AM
turbospool's Avatar
Default Re: Paint chipping in engine bay (azn98R)
or you can wait until they dent through your wheel well and just reweld it, thats what i did. All camber kits does this if its set to maximum correction. im set at 4 degrees of correction (max for skunk2 kit).
Old Jul 14, 2003 | 11:41 AM
PoW3l2BaN's Avatar
I have the ingalls camber kit and its still a problem. Mine happens only with extreme bottoming out. i still have stock upper control arms
Old Jul 14, 2003 | 11:43 AM
bb6's Avatar
bb6
I've seen the same problem on two integras, one with a skunk2 camber kit, the other with an ingalls...........
Old Jul 14, 2003 | 12:58 PM
2qwik2nv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Track rat &raquo;</TD></TR><TR><TD CLASS="quote">How much to raise? Depends. With higher rates, you may not have to raise it. With the same rates, just raise it until the UCAs stop smacking your towers. </TD></TR></TABLE>
How do you know when your high enough for the UCA to clear the body panel?
Old Jul 14, 2003 | 03:18 PM
not133t's Avatar
I have skunk2 and the same thing has happened but much worse im afraid.
Old Jul 15, 2003 | 06:32 AM
2qwik2nv's Avatar
Default Re: Paint chipping in engine bay (not133t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by not133t &raquo;</TD></TR><TR><TD CLASS="quote">I have skunk2 and the same thing has happened but much worse im afraid.</TD></TR></TABLE>
can you get a picture of the damage? I'm really interested in seeing it.
Old Jul 15, 2003 | 07:38 AM
Asahi's Avatar
I've seen the problem on other civics and integras that are too low so I will just reitterate what was asid above.
Also the stiff setup on the B6's is 12/8. I would not stiffen the front's. I have B6's with 10's on the front and the skunk camber kit and I do not have this problem. I can cjheck my notebook when i get hoime for numbers but I always measure from floor to jack point.
i'd raise it up a little and drive on the streets with the front shocks at setting 3 or higher. This is more likely going to help than raising it although it won't hurt.
Old Jul 15, 2003 | 07:51 AM
2qwik2nv's Avatar
Default Re: Paint chipping in engine bay (Asahi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Asahi &raquo;</TD></TR><TR><TD CLASS="quote">i'd raise it up a little and drive on the streets with the front shocks at setting 3 or higher. This is more likely going to help than raising it although it won't hurt.</TD></TR></TABLE>
So, driving on 1 or 2 isn't the best idea eh? me = What can I say, ignorance is bliss. Thanks for the advice and measurments when you get them. Your a big help.
Old Jul 15, 2003 | 08:05 PM
Edwin's Avatar
Raise that biotch that car is too low
